1st Jan 2011, 6:20 pm | #1 |
Help wanted Identifying PYE transistor radio
Hi everyone, I am hoping for my second post someone can identify this PYE transistor radio so I can get a service sheet for it.
Apart from the case needing cleaning the radio it self works perfectly, tuning is spot on and there is no distortion therefore I don't intend doing anything but clean the set but would like the manual for future reference. Big thanks in anticipation. David...... |
1st Jan 2011, 6:23 pm | #2 |
Re: Help wanted Identifying PYE transistor radio
No LW usually means it's an export model.
1st Jan 2011, 6:29 pm | #3 |
Oh look. AF11x transistors. You don't need a circuit to find the faults!
The nearest UK set appears to be the 1355. Cheers, Steve P.
If we've always had it, why is the Car Boot open? You're not sneaking another Old TV in are you...? Last edited by Steve_P; 1st Jan 2011 at 6:34 pm. |
2nd Jan 2011, 1:30 am | #4 |
Looks like someones modified it to use a PP9 rather than the setup suggested by the rear panel diagram.
2nd Jan 2011, 11:28 am | #5 | ||
Cosmetically the 1355 looks different so I am reluctant to buy a service sheet for it as I also need to understand the internal layout and battery arrangement as highlighted by Herald1360's post. I am however eternally grateful for the time all you guy's have taken to answer my query. Cheers n Beers, David...... Last edited by Coastwatch; 2nd Jan 2011 at 11:48 am. Reason: corrected spelling |
2nd Jan 2011, 1:03 pm | #6 |
The battery arrangement also suggests an export model. British makers usually designed their sets to use layer batteries such as PP9s at this time, but these were never popular outside Europe so the export sets were fitted with holders for cell batteries.
2nd Jan 2011, 1:06 pm | #7 |
Oop's last mention of PP3 should of course read PP9 and the picture reference should be "bottom left Pic 3" not Pic 4.
Too much leftover Christmas sauce was to blame.... Sorry |
2nd Jan 2011, 8:03 pm | #8 |
I'm including a few more pics to help identify this radio though it looks like I have a strange one here.
First pics are of the battery box which looks original and a pic of the serial No (628375) I found next to the VC then the Licence plate. I wonder is there a register of licence numbers similar to the American system which allows you to look up and identify the equipment on-line. |
3rd Jan 2011, 1:27 pm | #9 |
It looks very similar to the PE12 see here...
http://www.radiomuseum.org/r/pye_pe12tbqpe_12_tb.html but the speaker is on the other side, the PE12 does have MW and 3 x SW, maybe it's a later model?? but I'm only guessing... Peter |
3rd Jan 2011, 2:19 pm | #10 | |
Could mine be the later model as the one in your link looks to have the same type of battery plug shown on the insert card where as mine has pp9 snaps, also when did round IFT's end their production life, I seem to think they were phased out while square cans continued, mine is all square. Looking at the chassis around the tuning capacitor looks identical and the telescopic is the same with an identical tip. Comparing the quality of the case suggests mine was made to a cheaper standard to the one in the link, possibly for a less wealthy and demanding part of the World (perhaps a budget set or built to a price). I have just read the thread on the PE12TBQ in "Success Stories" and note the OP could not find a circuit diagram for this radio so the search is still on. I am indebted to you for advancing my search a bit further and thank you. Cheers n Beers, David....... |
