Old 15th Sep 2017, 3:20 pm   #1
David Simpson
Default CRATE GT80 Amp
Folks, my son has just acquired one of these for £20. Supposedly u/s, hence the plea - Dad, Dad - can you get it going ? Me - I'm out of my comfort zone - too modern, even though I'm guessing 1980's.
Has anyone got one, or has any info or experience, just to keep me straight. Its a hybrid Valve/ semi-conductor amp with a massive single 12" speaker. I reckon the speaker alone is worth more than £20.
Regards, David
Name:	CRATE AMP 1.jpg
ID:	149471   Click image for larger version
Name:	CRATE AMP 2.jpg
ID:	149472   Click image for larger version
Name:	CRATE AMP 3.jpg
ID:	149473   Click image for larger version
Name:	CRATE AMP 4.jpg
David Simpson is online now
Old 15th Sep 2017, 3:28 pm   #2
dragonser
dragonser's Avatar
Default Re: CRATE GT80 Amp
certainly worth more than £ 20-00 I would think.
I know another Crate ( of a different model ) that I worked on had a faulty transformer, I can't remember if it was output or mains ? But the fault could be something much easier to fix.
Regards Peter B
dragonser is offline
Old 15th Sep 2017, 3:48 pm   #3
Cobaltblue
Cobaltblue's Avatar
Circuit which I think is for the same model here https://elektrotanya.com/crate_gt-80.../download.html
The Output is all Solid state it has a few token double triodes of the 12AX7 12AU7 Varieties.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 15th Sep 2017, 4:02 pm   #4
mark_in_manc
I have a Marshall version of this kind of thing ('valvestate') - it's very versatile, produces a lot of different sounds (clean / dirty and all stops in between, which is the main point of the valve pre-amp) and is a lot more flexible and reliable than other more highly regarded 60s/70s all-valve amps I have used. Fixed, this should be very useful for performance as well as practice.
Do you have some valves to try in it? If the driver turns out to be knackered I can sell you a good 12" unit for 20 quid!
cheers
Mark
mark_in_manc is offline
Old 15th Sep 2017, 5:57 pm   #5
David Simpson
Thanks Guys for the info.
I've just got the Users Manual showing the spec & the block diagram. Its full of yanky teeny boppy ampy wampy language, which I don't understand :- "Funky Clean", "Bluesy Dirt", "Warm Tube Crunch", etc. I'll just stick with good old electronics fault-finding.
Regards, David
Old 15th Sep 2017, 6:18 pm   #6
buggies
buggies's Avatar
Novel idea using the valve filaments for the +16 volt rail fuse...
George
buggies is offline
Old 16th Sep 2017, 9:53 am   #7
Regards, David
Easy peasy...
How it sounds when new.
How it sounds after a few years on the road.
How it sounds after being tripped over by a drunken roadie.
Herald1360 is offline
Old 16th Sep 2017, 10:35 am   #8
David Simpson
Many thanks George for the circuit diagram link. I've heaps of spare ECC type double triodes, but I'm wondering if the BFP14/BFP9104 Mosfet PA's are easily acquirable these days, if needed ?
Regards, David
Old 20th Sep 2017, 5:58 pm   #9
David Simpson
More fault finding done - Mains T/F u/s , as are the two rectifying diodes (1N4087's) for the +175V HT line for the valves.
I found that someone had not changed the T/F tappings from 110V to 220V. The Pri now draws 1.5A when my Variac is just set to 40V !
I wonder how easy, if at all, one could get a replacement transformer ?
Regards, David
Old 20th Sep 2017, 8:55 pm   #10
Ed_Dinning
Hi David, probably a simple reverse engineer and rewind job (without a 110v tap).
Ed
Ed_Dinning is online now
Old 21st Sep 2017, 11:09 am   #11
David Simpson
Right enough Ed, I guess a rewind for just 240V should do. With the T/F completely disconnected - I used my variac to feed the 85V & 40V bridge rectifier circuits & they seemed fine.
There is loads of space on the chassis & in the cabinet to mount individual mains transformers for each of the three voltage rails (+175V, +&- 85, & +&- 40V). I'll see what I've available or can scrounge meantime.
Regards, David
