Old 17th Sep 2017, 7:36 pm   #1
cernem1alt
cernem1alt's Avatar
Default Bush DAC90A problems.
It's that old chestnut again a bust waveband switch on a DAC90A
Sadly mine is to far gone and I was wondering would a modern 2 pole 2 throw rotary switch surfice? has anyone fitted a modern replacement if so what?
I see there are a few posts on repairing the old one and a bit about modifying a 2 pole 4 throw so any ideas
sorry if this is a repeat topic
Many thanks Mike
cernem1alt is offline
Old 18th Sep 2017, 9:41 am   #2
Radio Tech
Radio Tech's Avatar
Default Re: Bush DAC90A waveband switch again
Hello Mike
I am pretty sure that you would be able to fit a modern two pole two way switch, have a look at either ESR electronics or Rapid electronics, these switches can be set to up to 12 positions as the stop on them is adjustable. Failing that try electrojumbe and if push comes to shove I might even have one that will suite.
Best wishes
Ken
Radio Tech is offline
Old 18th Sep 2017, 11:27 am   #3
David G4EBT
David G4EBT's Avatar
I'm sure there's been a thread - maybe in 'Success Stories' showing a neat way to replace the DAC90A bandswitch.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 18th Sep 2017, 7:48 pm   #4
cernem1alt
cernem1alt's Avatar
Thank you Ken and David for your replies I am going to go with the adjustable rotary switch I found one today online now I have never come across one of these yet believe it or not so I shall have to pay attention to wiring it up and fixing the stops etc another radio learning curve just what its all about
Old 18th Sep 2017, 7:52 pm   #5
Ed_Dinning
Hi Gents, this switch is a pretty slimline type, not all modern ones will fit in, although electrically they will do the job.
Ed
Ed_Dinning is online now
Old 18th Sep 2017, 8:11 pm   #6
AC/HL
AC/HL's Avatar
They're a fairly common radio and occasionally do get broken for spares. You could try a request in the parts wanted section.
AC/HL is offline
Old 18th Sep 2017, 8:49 pm   #7
Dickie
I'm about to break one for spares (cabinet in many pieces and a bent chassis!) so I'll see if the wavechange switch is serviceable.
Regards,
Richard, BVWS member
Dickie is offline
Old 18th Sep 2017, 10:55 pm   #8
cernem1alt
cernem1alt's Avatar
I did rather think size might be an issue it was a right performance getting the old one out, I think many years ago someone snapped the waveband on my set then tried to wrench off the front knobs to get inside the box and chipped those however they have been repaired using some stuff I have called JB Weld then smoothed to shape with my dremel small lick of paint and only I know. The waveband switch lost the copper ballbearing piece the set from the smell of it (lavender water old ladies face powder) I reckon got put in a wardrobe and forgot about. Richard if you have an intact one I may get back to you if I cant work it with this modern rotary switch
Regards All
Mike M1ALT
Old 21st Sep 2017, 5:50 pm   #9
cernem1alt
cernem1alt's Avatar
Update I tried fitting a modern rotary switch that is a no no not enough room so I am going to have to find an original Bush DAC90A waveband switch
Mike M1ALT
Old 21st Sep 2017, 10:27 pm   #10
David G4EBT
There's a neat diagram somewhere - either on or off the forum, which shows how to use a Lorlin wave-change switch as a replacement, but I'm blowed if I can find it. I didn't bother bookmarking it as the DAC90A is my least favourite radio and holds no attraction to me.
However, this youtube video might be of interest, by a guy called Yannis Karalis, who supplies new DAC90A dials of any type, has designed and can supply a PCB to replace the tag-strip, has done various improvements (dial lights, hum reduction OPT rewind etc). He's also drawn up what looks to be a neat and comprehensive '90A repair manual.
'Bush DAC90A Switch repair':
https://www.bing.com/videos/search?q...B8AC&FORM=VIRE
Here's his website on 'Bush DAC90A Easy Restoration':
https://www.yanniskaralis.com/bush-d...sy-restoration
A low resolution section of the manual can be found here, which you can judge for yourself:
https://docs.wixstatic.com/ugd/ac5ed...fae80f794f.pdf
Hope that's of interest to DAC90A fans.
Good luck with the switch repair Mike.
David.
BVWS Member.
Old 23rd Sep 2017, 2:08 am   #11
G8UWM-MildMartin
A Lorlin switch (2 pole 6 way, or 3 pole 4 way or 4 pole 3 way, shorting) as sold by Maplin, etc., certainly will fit, unless the design has changed in the last 11 years.
I did it by setting the mechanical stop to 2-way, chopping off all the unused tags, bending the remaining ones almost flat, working out its orientation, and re-arranging the wiring (slightly longer on one and on the opposite sides to original) so the tag connected to chassis could be allowed to short to the bracket where it just about touched, if it wanted.
G8UWM-MildMartin is online now
Old 23rd Sep 2017, 11:41 am   #12
cernem1alt
cernem1alt's Avatar
Happily I have sourced an original
Old 3rd Oct 2017, 1:01 am   #13
cernem1alt
cernem1alt's Avatar
Default Bush DAC90A C17 tone Cap question
Following on from a purchase of a DAC90A repair kit Having replaced various caps and bulbs I now turn to C17 tone corrector 1x .001 (1nf) to replace .003 for improved sound. My sets tone is quite pleasant to my ear the old C17 looks ok and going by the old saying "if it's not broke don't fix it" am I missing something here if I don't replace C17? curious to know the pros and cons of changing it.
Thanks Mike
Old 3rd Oct 2017, 3:09 am   #14
MurphyNut
MurphyNut's Avatar
Default Re: Bush DAC90A C17 tone Cap question
I'd be interested to hear what's said, from what I gather it's meant to improve the treble response.
I own two DAC 90A's and not changed C17 as I don't have a problem with the sound.
Clive
MurphyNut is offline
Old 3rd Oct 2017, 7:52 am   #15
crackle
If C17 is a waxy paper capacitor then it will already be leaking DC current and it will get worse. This will eventually effect the way that V3 works, and may lead to R10 overheating.
If you like the more mellow tone caused by the 0.003uF cap, then why not replace it with a new 0.0022 or .0033 uF 630v cap.
Worries will then be over.
Mike
crackle is offline
Old 3rd Oct 2017, 8:11 am   #16
HamishBoxer
HamishBoxer's Avatar
I think if it is across the sound o/put transformer then most members advise a cap rated at 1500V.See previous posts of which there are many on these excellent little sets.
As stated high risk the wax one will be leaky after all these years.
HamishBoxer is offline
Old 3rd Oct 2017, 9:36 am   #17
ukcol
ukcol's Avatar
C17 is connected between the anode of the audio triode and chassis. I would agree that the original wax capacitor here should always be changed for a modern type.
There are a number of mods for the DAC90A developed by P F Vaughan (Kalee20) that may be of interest to you - here.
ukcol is offline
Old 3rd Oct 2017, 12:07 pm   #18
ThePillenwerfer
ThePillenwerfer's Avatar
I've done several of these and only once lowered C17 to 390pF. I couldn't tell any difference.
I'd certainly change the original cap though; what you change it for is up to you. I've found that capacitors which are still OK quickly fail when you start using the set so change the lot while I'm at it. For all that it doesn't matter a mixture or old and new looks like a job half done.
ThePillenwerfer is offline
Old 3rd Oct 2017, 12:18 pm   #19
paulsherwin
paulsherwin's Avatar
I would also change this cap.
The DAC90A does have a rather woolly sound to modern ears. People liked a lot of top cut in the 50s and most radios from that era sound similar.
paulsherwin is offline
Old 3rd Oct 2017, 6:35 pm   #20
Ian - G4JQT
Ian - G4JQT's Avatar
I always change C17 (Bush numbering) to about 500p. It really only needs to remove any residual IF. The original value has far too much treble cut for modern ears, and remember that the audio as transmitted now almost certainly has less treble than 60 years ago, so maybe it sounded ok then, but not now.
There's a mention on this forum somewhere that this particular cap may be a minor error that Bush never noticed. I think that's unlikely as it's the same value in the almost identical circuit of the Bush DAC10.
The treble cut capacitor across the output transformer (to reduce the shrillness of third-harmonic distortion?) is also a bit brutal and I reduce that too - but as stated above, ensure it's 1kV or thereabouts.
For those who don't notice a difference, maybe it depends how tightly set the IF bandwidth is. I align mine so it's relatively broad so local stations and my 'pantry' transmitters sound really nice after these two caps have reduced values.
Ian
Ian - G4JQT is offline
