Old 1st Oct 2017, 11:38 pm   #21
AC/HL
AC/HL's Avatar
Default Re: ID This Device?
It's the physical aspect that intrigues me. Four pins commoned at one side, the B4 pattern may be just to fit available sockets, but a screw terminal at the other?.
AC/HL is offline
Old 1st Oct 2017, 11:48 pm   #22
Radio Wrangler
Radio Wrangler's Avatar
Is it just a terminal, or is it also a gap adjuster?
Radio Wrangler is offline
Old 2nd Oct 2017, 7:27 am   #23
G3VKM_Roger
G3VKM_Roger's Avatar
I think the plug-in base and the terminal may indicate that the equipment that used the crystal could change frequency but not as fast as, say, swapping a 10X type. The 4BA tapped hole in the underside of the base may indicate that the crystal(s) were firmly mounted, so again not a quick job to swap freqs.
The terminal is just that, there is no locking nut or other adjustment to the threaded rod part.
The Trawler Band was often marked on domestic sets, as were aircraft bands but I can't recall seeing those bands on pre-WW2 sets, any domestic set collectors care to comment? I will see if I can find some info on the 1947 Atlantic City Conference when a lot changed as regards frequency allocations. I can recall reading objections by European nations to amateur use of 1750-2000kHz ("Top Band") which might indicate when 2MHz began to be used by ships and 2017kHz in particular.
Roger
G3VKM_Roger is offline
Old 4th Oct 2017, 7:39 am   #24
G3VKM_Roger
A brief search turned up the frequency allocations agreed at Atlantic City in 1947. 2182kHz is mentioned as the R/T distress freq and the band my crystal is in is allocated to the Mobile Service, which I assume includes Maritime Mobile.
However, IMHO the crystal I have has a pre-war origin, by 1947 much smaller crystals with internationally agreed holder types were abundant.
Thanks for the interest from members, who I know always like a mystery!
Roger
