Old 29th Sep 2017, 7:16 pm   #1
G3VKM_Roger
G3VKM_Roger's Avatar
Default ID This Device?
Can any anyone ID the (possibly military) gizmo in the attached photos? It is mostly brass with an ebonite or similar top and the base has four non-brass solid pins in a British B4 pattern, all drilled into the base. The insulated top has a single terminal and the base and top are riveted together.
The top is marked "X1141" and "958" is also scratched onto the top, possibly a serial number. The "anode" pin of the B4 is marked as "5" and finally the middle of the underside is drilled for a 4BA screw.
Plugging this into a B4 base would obviously short all the pins together, so a piece of test gear comes to mind. There is no electrical connection between the terminal and the base and pins, measuring on the highest range of my mulitmeter and there is no discernable meter "kick" which might mean there is a capacitor inside.
Any ideas?
73
Roger/G3VKM
ID:	150077   Click image for larger version
G3VKM_Roger is offline
Old 29th Sep 2017, 7:27 pm   #2
ms660
ms660's Avatar
Default Re: ID This Device?
Xtal?
Lawrence.
ms660 is offline
Old 29th Sep 2017, 7:51 pm   #3
HamishBoxer
HamishBoxer's Avatar
If not a Xtal than possibly a Coil? What does a meter reading give on Ohms?
HamishBoxer is online now
Old 29th Sep 2017, 11:07 pm   #4
G3VKM_Roger
No, nothing on my analogue multimeter, on any Ohms range. A crystal is a possibility as it would show nothing on a meter whereas a capacitor might cause a kick on the meter as it charges up.
I will try hooking it to my crystal tester.
Roger
Old 30th Sep 2017, 9:41 am   #5
ms660
ms660's Avatar
In the 2nd photo what's the four brass looking things on the top?
Lawrence.
ms660 is offline
Old 30th Sep 2017, 1:56 pm   #6
G6Tanuki
G6Tanuki's Avatar
Aren't they just the top ends of the 4 pins?
I'm betting that it's either a crystal or some sort of plug-in capacitor: I recall that WWII-era transmitters sometimes used plug-in "antenna-shortening" capacitors (in series with the antenna) to help a radio designed for short whip-antennas (well less than 1/4-wave) to match a longwire that may be more than 1/4-wave long.
G6Tanuki is offline
Old 30th Sep 2017, 2:00 pm   #7
ms660
ms660's Avatar
If they are then it doesn't look like B4 to me, needs confirming maybe.
Lawrence.
ms660 is offline
Old 30th Sep 2017, 7:20 pm   #8
G3VKM_Roger
They appear to be brass rivets that hold the base to the terminal board.
Roger
Old 30th Sep 2017, 7:23 pm   #9
ms660
ms660's Avatar
Thanks, it's a mystery so far.
Lawrence.
ms660 is offline
Old 30th Sep 2017, 7:36 pm   #10
G3VKM_Roger
No, the brass fittings on the top appear to hold the ebonite(?) terminal board to the brass bottom, I think they are rivets as they are slightly proud of the board, suggesting a flat head?
The pins in the base definitely fit snugly into a B4 base, if by B4 you mean a PM2 valve base. It's not the American 4-pin base which has large and small pins. The base pins do not align with the (?) rivets on top, which are at 90 degree points around the board.
If I get chance tomorrow, I will hook it up to my sig gen which has a crystal tester built-in and I will also try it on my capacitance bridge. If it does have a antenna shortening function then I would expect the capacitor to be of a low value, 100pf at most.
73
Roger
Old 30th Sep 2017, 10:11 pm   #11
Silicon
Spark gap for lightning arrester?
Silicon is offline
Old 1st Oct 2017, 8:02 am   #12
G3VKM_Roger
One thought occured to me is that "X1141" referred to an RAF aircraft serial number but searches on-line seem to indicate that serial was never issued.
Roger
Old 1st Oct 2017, 8:06 am   #13
G3VKM_Roger
Rather lightly engineered for such huge currents, maybe? Possibly static discharge device?
Have had a close look at the thing this morning with a magnifying glass but, other than the number "5" next to the "anode", pin I can't see any marks other than those in my O/P.
Roger
Old 1st Oct 2017, 10:34 am   #14
G3VKM_Roger
OK, it is a crystal! Oscillates at 2017.88 kHz on my tester. I can't see that the X1141 and 958 numbers on the top have any relation to the frequency it works at.
Presumably, there was a B4 crystal holder or holders in the equipment and selection was made by a flying lead. The freq may indicate marine band but also older military kit, something like the early numbers of the Wireless Sets range?
OK, so we know what it is but what does it belong to!?
73
Roger
Old 1st Oct 2017, 10:48 am   #15
ms660
ms660's Avatar
That was my initial thought, it looks very Marconi (ish)
Lawrence.
ms660 is offline
Old 1st Oct 2017, 11:11 am   #16
G3VKM_Roger
Yes, Lawrence, a good guess! I've had a quick look thru Wireless for the Warrior Compendium 1, which covers the Spark to Larkspur era and I cannot see anything that resembles the crystal. Most of the post-WW1 sets had master oscillators and only the later WS No 1 and 3 onwards had crystal oscillators as an option.
If it is marine band, then a pre-WW2 list of ship working frequencies might show the crystal as being for a ship TX. I have some data on that subject, if I can find it!
Roger
Old 1st Oct 2017, 7:11 pm   #17
Radio Wrangler
Radio Wrangler's Avatar
Crystals have two resonance modes, series and parallel, and it could have been used on either. So does either mode land on a popular maritime frequency?
Radio Wrangler is online now
Old 1st Oct 2017, 8:24 pm   #18
Jon_G4MDC
Jon_G4MDC's Avatar
Do we think so for such an early one?
And at such low frequency, would that be significant?
I'm happy to bow to greater knowledge but I would have thought a few 10's of PPM at the most. I will say have never seen one like that before all the same!
Jon_G4MDC is offline
Old 1st Oct 2017, 9:41 pm   #19
G3VKM_Roger
I have a copy of a report on the RMS Queen Mary's radio installation dated 1936 and that shows LF and MF freqs from 111.5 up to 500kHz. After that, the next freq they list is 8354kHz. It looks likely that there wasn't an allocation to the Maritime Mobile Service around 2MHz pre-war, if there was it's odd that a high-traffic ship like the QM didn't make use of it.
Roger
Old 1st Oct 2017, 11:17 pm   #20
Radio Wrangler
That's a big gap. I wonder when the "trawler band" was assigned? I've found references to the date of ending 2182, but not to the start. Someone must have been using 2.xxxMHz for some purpose?
As a kid with an AR88 in the sixties, fishfone improved my vocabulary no-end.
Anyway, even old crystals have both series and parallel resonance modes The spacing depends on the holder capacitance and the motional inductance. Probably a few kHz.
