Old 2nd Apr 2012, 11:21 am   #21
BBRQ229
BBRQ229's Avatar
Default Re: Eddystone EA12 - front end problem
David, my apologies for delay in response, but have been otherwise occupied and just thinking of having another go at this EA12 - which cost me a small fortune, only to be 'dead on arrival' - or nearly so. Keen to get it working therefore.
Will post progress or lack of it in a couple of days.
Tony H
Onwards and Sideways
BBRQ229 is offline
Old 2nd Apr 2012, 8:11 pm   #22
Yeah, EA12s were sought-after radios in the 1960s and have matured nicely into sought-after collector's pieces with prices to match.
As has been said earlier, they were quite competently designed and worked well, provided you could get used to tuning across each band backwards. It's very well worth fixing, and shouldn't be too much bother. Faults are always simple when viewed in retrospect.
Eddystones have one nasty flaw. Their lovely low-geared smooth tuning is usually done with a thin shim disc gripped between sprung cones, giving very high reduction ratio in the first stage of gearing. Any wear in the tuning knob bush and a little movement of the axis of the shaft is equivalent to a significant amount of rotation. Any competent model engineer can make spares, but you need the right size reamer to finish it properly.
When you've got yours going, you might stir me into opening mine
Radio Wrangler is offline
Old 7th Feb 2016, 2:26 pm   #23
Superhet Si
Superhet Si's Avatar
Sorry to drag this up again but I have the same problem with my EA12.
It looks to me like the fault is in the RF amp (v1) although this valve is good.
The cathode of V1 connects to the muting circuit, so check the standby switch contacts and also the crystal switch. If I connect an aerial to pin 1 of the valve socket via a DC blocking cap I get reasonable performance.
Also checking c32 for a short.
Superhet Si is offline
All information and advice on this forum is subject to the WARNING AND DISCLAIMER located at http://www.vintage-radio.net.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
