Old 26th Apr 2013, 9:56 pm   #1
Barnmead
Barnmead's Avatar
Default New scale etc. for a sick AVO Model 40
AVO Model 40 s/n 417599-1146
I have recently given a model 8 Mk4 and a model 40, both were filthy and had several faults when I received them. Both had resided uncared for gathering dust in a garage for many years. The model 8 was missing a reset button and one of the high voltage terminals and was soon cleaned and back in working order. It did have a surprise, there was a VC1 voltage converter in the battery compartment. I have posted pictures of this elsewhere on this forum.
The model 40 was another kettle of fish. The glass appeared to have been replaced at some time and a number of repairs had been made over the years. Dates pencilled on the back of the meter scale bear witness to this as did fragments of glass in the case. A label on the side indicated that it had been calibrated in 1975. The Q resistance adjustment knob was broken and the battery cover was missing. The corroded and leaking 1.5 volt cell had to be drilled out of the battery compartment ( two holes and long nosed pliers!) After washing and drying the outside and gently easing the meter from its aluminium case I found that the meter movement was OK but a poorly soldered connection had come adrift. Several of the original resistors had been haphazardly replaced and the contents of the leaking 1.5 volt cell had seeped through to the interior and corroded two of the copper contact springs. Nevertheless the instrument looked salvageable, it was a model that I did not have. and would bring my total to seven.
When I next came to work on it a few days later, my heart sank, the scale had cracked up and peeled away from the brass backplate (see the pictures below). The most remarkable thing was that the brass had a perfect replica of the scale markings beneath the paint.
It was a long shot, but I posted a request on the forum and Phil Harris kindly sent me a scan of scale from a model 47A meter which I modified and printed out at 300 dpi. I use an iMac so imported the jpeg file that he sent me into Graphic Converter, reduced the saturation, improved the white balance, added a little sharpening and printed out a fast draft copy. From this I calculated the appropriate reduction in size to fit my brass scale plate. Another fast draft copy to double check, then the process of altering the scan to include the still legible serial number and part number from my instrument. I then printed out a single A4 page with three of the final images on 'extra white' 90 gsm paper. Cutting the curved opening for the mirror with a scalpel was the most difficult part. The scale was then glued using a 'Pritt Stick' to the brass backplate.
A response from PM Munro to my plight advised that early models such as this were hand calibrated and 12 cardinal points were marked on the scale plate with punch marks and the marks between were made with a proportional pantograph. I was pleased to find 24 of these these indentations on the brass plate when all the paint had been removed.[https://www.vintage-radio.net/forum/...63#post601463]
I have a theory about the flaking. I know from its condition and from the previous owner that the meter has been poorly stored and in a dusty and possibly damp atmosphere. In bright sunlight the black lettering would get hotter than the white background and a combination of moisture and warmth would leach out something in the paint which attacked the brass. The effect would be enhanced in the hotter areas. The back of the paint flakes is light green with no indentations or marks corresponding to the lettering.
Having re-assembled the meter I turned my attention to the broken 'Q' knob. I discovered that by undoing the nuts that hold the wiper in place the brass rod and broken pieces of bakelite knob could be removed. I found a small 6BA bakelite terminal which was the same diameter as the broken one (though a little deeper) and drilled the brass spindle to take a 6BA screw which I soldered in place to attach the terminal. A small piece of black plastic tube was used to make up the diameter. You can hardly notice the difference in the photograph.
The lettering was touched up with off white emulsion paint applied with a very fine water colour brush and allowed to dry for a very short time before being wiped away with a soft cloth. The front panel was cleaned using detergent and a tooth brush and finally given a spray with furniture polish.
I tested the meter on several ranges and found that it reads between 1% and 2% high depending upon the deflection, but that is understandable with a foreign scale.*I wired in a press stud connector to enable the 9 volt supply to be provided by a PP3 battery and two wires for connection to a 1.5 volt cell. A piece of aluminium was cut and drilled using a battery cover from one of my other meters as a template to complete the job.
ID:	79102   Click image for larger version
ID:	79103   Click image for larger version
ID:	79109   Click image for larger version
Richard
Barnmead is offline
Old 27th Apr 2013, 9:44 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: new scale etc. for a sick AVO Model 40
Very nice work, Richard. Another one brought back from the dead.
Nick.
Nickthedentist is offline
Old 30th Apr 2013, 10:25 pm   #3
Phil G4SPZ
Phil G4SPZ's Avatar
Nice job, Richard, and happy to have been able to help. Nice to see the finished article, and to know that another classic Avo instrument lives to indicate again.
Have you tried slight adjustment of the magnetic shunt to correct the over-reading? PM me if you need guidance on how to do this.
Phil
Phil G4SPZ is offline
Old 1st May 2013, 11:06 am   #4
Barnmead
Barnmead's Avatar
Default Re: New scale etc. for a sick AVO Model 40
Hmm, why didn't I think of that? Something to do when I have an idle hour or so. Thank you for your help and kind comments.
Richard
Barnmead is offline
