Old 30th Sep 2011, 1:49 pm   #1
QWENIX
QWENIX's Avatar
Default Solartron Vari-Pack SRS153-2 mains fuse
Dear members,
I' ve got a PSU Solartron Vari-Pack SRS 153-2. I do have the cirquit layout but I guess they (Solartron ) forgot to mention the mains fuses value.
I know this PSU takes 140VA. So using mains 230 volts that makes in normal operation 600 mA.
What fuse should I use .. cause switching on takes more than 600 mA.
bets regards,
Qwenix
QWENIX is offline
Old 30th Sep 2011, 2:02 pm   #2
ppppenguin
ppppenguin's Avatar
Default Re: Solartron Vari-Pack SRS153-2 mains fuse
Mine has a 3A fast blow mains fuse. Is this correct? Perhaps, perhaps not. The HT fuse is 250mA on the circuit diagram.
I fitted an HT switch to mine, so that you can set the voltage before you connect to the load.
ppppenguin is offline
Old 30th Sep 2011, 2:28 pm   #3
Tim
Tim's Avatar
1.2-1.5 amps?
Tim is offline
Old 6th Oct 2011, 11:21 am   #4
QWENIX
QWENIX's Avatar
Thanks for al the replies,
mine has the 3 A mains fuse .... so I guess this has to be the correct one ?
Best regards
Qwenix
QWENIX is offline
Old 6th Dec 2011, 1:45 pm   #5
DrSound
DrSound's Avatar
I have just acquired on of these and mine has a 3A RS antisurge fitted.
Although I do seem to have a problem with the HT output. I get 230Vac and no adjustment? I thought this supply was DC 0-500V? Any help or guidance gratefully received.
DrSound is offline
Old 6th Dec 2011, 10:35 pm   #6
QWENIX
QWENIX's Avatar
H+ and H- defference should deliver (mine does) almost full scale deflection 55OV = rectified. Against chassis no rectified voltage measurable (digital meter) Only Ac difference 73 Volts~.
The other 3.2 V AC ~ against chassis so 2 times makes difference 6.4 V~ AC
Best regards
Qwenix
QWENIX is offline
Old 6th Dec 2011, 11:02 pm   #7
ppppenguin
ppppenguin's Avatar
DrSound, welcome to the forum. It looks almost impossible for the HT output to be 230VAC. It would be very difficult for AC to get through the rectifiers and the series stabilisers. I've attached the schematic in case you don't already have it.
We don't yet know your level of expertise when working with valves and high voltages. Please be aware that the voltages and currents in this unit are potentially lethal.
Old 7th Dec 2011, 9:03 pm   #8
QWENIX
QWENIX's Avatar
ppppenguin, can you send me the this schematic by PM. Please in high solution.
best regards
Qwenix
QWENIX is offline
Old 8th Dec 2011, 3:04 pm   #9
DrSound
DrSound's Avatar
Thank you for the schematic Pppppenguin.
I am a RF engineer with little valve experience wishing to modify some valve audio amps. I have acquired a bit of kit for my home lab., including the vari-pak and am firstly determining that the kit functions correctly. I will print off the schematic and re-measure outputs.
DrSound is offline
Old 9th Dec 2011, 12:34 pm   #10
DrSound
DrSound's Avatar
I have printed the schematic off, but it is illegible.
Could you post a high res version please?
DrSound is offline
Old 9th Dec 2011, 12:52 pm   #11
ppppenguin
ppppenguin's Avatar
The problem is that the forum software automatically re-sizes images. I'll try it inside a zip file.
