Old 17th Jun 2017, 6:10 pm   #1
G4YVM David
G4YVM David's Avatar
Default Field phones Type F
I have powered up my field telephones and they almost work! The only thing which doesnt is the microphone circuit in one of them. (Mic inserts swapped and tested satis, ditto coils.)
Anyway, question... is it okay to disconnect EVERYTHING except the bell circuit and the phone, i.e. run the phone as a straight phone, in an effort to find the fault or even just bypass it? By @okay@ I mean, it wont induce further faults?
D
G4YVM David is offline
Old 17th Jun 2017, 8:33 pm   #2
Dave Moll
Dave Moll's Avatar
Default Re: Field phones Type F
If you exclude the telephone and bell circuits, what else is there to disconnect than the magneto. And leaving that connected isn't a problem as long as you don't turn the handle.
Although I've never felt the inclination to do it myself, I know others have successfully connected field telephones to "normal" telephone lines.
I'm not sure, however, whether this would be effective as a fault-finding technique.
Dave Moll is offline
Old 17th Jun 2017, 10:48 pm   #3
russell_w_b
russell_w_b's Avatar
Have you measured a d.c. voltage across your mic, starting at the handset plug (for easiness) and heading towards the handset?
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 18th Jun 2017, 7:25 am   #4
G4YVM David
Yes. There isn't one. I suspect wiring around the buzzer "relay" so am bypassing that. It's broken, glued and bodged.
D
Old 18th Jun 2017, 8:54 am   #5
russell_w_b
The mic current from the 3V winding flows through a couple of primary windings of the induction coil / buzzer assembly, but also through contacts on the cradle switch and a set of N/C contacts on the buzzer push-button. Are these switch contacts dodgy?
If you by-pass the induction coil / buzzer by taking the battery positive lead directly to the mic terminal on the handset, you should be able to narrow the fault down. I expect you have a cct diagram but here's one anyway. You have nothing to gain by connecting the instrument across a DEL as the tele would still require a separately-excited mic, and this is where your fault lies.
Regds,
Russell W. B.
G4YLI.
Old 18th Jun 2017, 9:58 am   #6
G4YVM David
Thanks Russell. I found the cct on this site in another thead and the system you advocate for narrowing down is exactly what I'm doing, so I guess I'm going right!
Thanks for your info.
D
