4th Feb 2015, 11:29 pm | #21 |
Re: Need help with my Telequipment type D83
Oh absolutely!
I have the V4 manual and can confirm that it is not much use with the V2 plugin although if you look carefully enough, although the boards and board layout is very different, some parts of the circuit are identical. A V2 Manual would be great Steve.
Those who lack imagination cannot imagine what is lacking... |
20th Feb 2015, 11:22 pm | #22 |
Do you know what the voltage per division is on the CH1 output socket?
On my V3 it is 0.25V/division. Al
I won't tell you how I discovered that. |
20th Feb 2015, 11:46 pm | #23 |
Al,
If you are asking me about the v2 volts/div the answer is no, not off hand... Steve.
