Old 14th Oct 2011, 3:54 pm   #1
Default Signal Corp. LS-3 Speaker
Hello all, I have a Signal Corp. LS-3 speaker and the input jack is smaller than the standard 1/4" jack any one know which jack this is.
Old 14th Oct 2011, 4:11 pm   #2
G4XWDJim
G4XWDJim's Avatar
Default Re: Signal Corp. LS-3 Speaker
Those smaller jacks are quite common on American equipment. I think they're nearly always 3 contact, a bit like a stereo plug. I can't find one to take a photo of but they shouldn't be too difficult to find.
A duff mic. like a T17 would yield one.
Jim
G4XWDJim is offline
Old 14th Oct 2011, 4:22 pm   #3
Thanks for the reply Jim, yes I think they might be common enough for me to obtain one from somewhere, failing that I should be able to cobble up something. I've got it working on a match stick jobbie at the moment.
Thanks.
Old 14th Oct 2011, 6:13 pm   #4
OscarFoxtrot
OscarFoxtrot's Avatar
If it's 4.4 mm (0.173") dia. then it's probably a "bantam" jack.
Eg Farnell
OscarFoxtrot is offline
Old 14th Oct 2011, 6:47 pm   #5
Thanks, I have also now been informed that the jack plug to fit the LS-3 is commonly known as a PL68.
(Addition) According to my calipers the socket fitted to the speaker is just a fraction over 5 mm dia.
Old 14th Oct 2011, 6:55 pm   #6
M0FYA Andy
FairRadio have them listed at $8 new, $6 used............
I think they have a $20 minimum order.
Andy
M0FYA Andy is offline
Old 14th Oct 2011, 7:02 pm   #7
Thanks Andy. I see they have the LS-3's also, although I am happy with one I have.
Old 14th Oct 2011, 7:21 pm   #8
OscarFoxtrot
.206" COMMERCIAL HEADSET MIC PLUG
£8.93 here; P&P looks reasonable. No connection with / experience of the seller.
http://shop1.actinicexpress.co.uk/sh...php?section=27
Old 14th Oct 2011, 7:22 pm   #9
M0FYA Andy
I dread to think what the postage for an LS-3 would be from the US!
Andy
Old 14th Oct 2011, 7:25 pm   #10
Andy...PM me if you want to know!
Old 14th Oct 2011, 7:32 pm   #11
Looks like that's the one.
Old 21st Oct 2011, 9:45 am   #12
vosperd
vosperd's Avatar
I think it is 3/16".
If you are careful you can drill the socket out to 1/4" if you are don't mind it not being original.
Don m5aky
vosperd is offline
Old 21st Oct 2011, 5:05 pm   #13
Hello Don I have found a source for the Jack Plug, years ago I would not hesitate to drill the socket out but not now, one of the reasons is that I can't get the socket out to do an operation like that as despite removing all the cabinet screws the front plate is well sealed on to the main box with the original MFP treatment and is stuck solid.
