24th Oct 2014, 2:02 pm | #1 |
Panel finishing.
When using Letraset or Inkjet based Crafty Computer Paper it's usual to finish off with a coat or two of lacquer. I'm getting close to the end of my last spray can of Maplin's clear PCB lacquer and am looking for a replacement. It's still available I believe but I'd like to look elsewhere.
Most car spray cans these days seem to be acrylic so does anyone know if that is suitable for spraying over Letraset. Older car spray cans of cellulose would react badly and ruin the work. Has anyone tried a clear acrylic spray for this purpose. Jim Last edited by paulsherwin; 24th Oct 2014 at 2:19 pm. |
24th Oct 2014, 2:12 pm | #2 |
Re: Panel finishing.
Yes I have, it (the acrylic) does react a bit with Letraset, a couple of very light coats first does the trick. It is more of a 'not sticking to' rather than a crinkle of the letters.
25th Oct 2014, 4:52 pm | #3 |
I can't comment on the effect of acrylic lacquer on Letraset, but it works beautifully on Crafty Computer Paper. I give it a couple of "mist" coats, then a couple of slightly heavier ones, just to make sure the whole transfer is coated.
Barry |
25th Oct 2014, 11:17 pm | #4 |
I've used acrylic lacquer over Letraset with no problem before now.
Black acrylic paint, white Letraset, half a dozen coats of lacquer looks very nice, though I say it myself! Addendum: I've had less success on wood - used it to refinish a Pye Black Box, and the finish crazed after a few months. |
26th Oct 2014, 3:21 am | #5 |
Has anyone tried printing the whole panel using Word (or similar)? I've done this in the past and then cut holes for the controls and placed the sheet behind a thin perspex panel similarly cut for controls.
Obviously using a more accurate method for on-screen measurement and hole placement would improve the technique (it's been a number of years since I last made one) but the likes of Google Sketchup could do this quite nicely. Using a quality printer, photo-mode and gloss finish results in a very professional fiinish. It looks and works beautifully - until you get water behind it! Mabye I should have lacquered it as well?? Fortunately that's only ever happened once with me. |
26th Oct 2014, 11:47 am | #6 |
Thanks for the comments chaps. I'll get some acrylic lacquer and give it a try although with the difficulty of getting Letraset or an equivalent these days it might be something I have to give up soon.
The Maplin PCB varnish although I've used it regularly takes a long time to completely dry, feeling tacky for a day or two which slows down the work rate. Jim |
26th Oct 2014, 12:33 pm | #7 |
I have done this a few times with Adobe Illustrator, printing both onto photo paper and plain paper, covering that with a heavy transparent sticky-back plastic wrapped around the panel edges. I have so much trouble moving text and images in Word that I try to avoid it!
Latterly I've been using inkjet-printable transfer sheets and spray-coating those with lacquer. This is not quite as easy to do with a big panel because the 'decal' sheets are not easy to handle in larger sizes. I have resorted to cutting out the individual areas of transfer before placing them in the correct place, but then you can see the edges after it's been lacquered. I'm just planning the panel for a 3U rack-mount case, so there may be an update before long, especially if I get an A3 page through my printer.
26th Oct 2014, 12:58 pm | #8 |
Just a thought - I have a lovely old Taylor-Hobson engraving machine here which anyone is welcome to use if in the near of Anglesey.
Les. |
26th Oct 2014, 1:34 pm | #9 | |
For protection - a 2mm sheet of 'Lexan' polycarbonate fitted over the entire front panel works well, and looks particularly good when held on using 3mm 'domed' nuts. |
26th Oct 2014, 4:11 pm | #10 | |
Jim |
26th Oct 2014, 5:43 pm | #11 |
I have successfully used clear acrylic lacquer in the past, but lately I prefer to print the front panel design on good quality plain paper and then laminate (using 150 micron lamination pouches). Cut-outs can then be made using a craft knife or paper hole punches (ideal for LEDs). The resulting laminate is sufficiently strong to be able to cover any unwanted holes on front panels, meaning that previously used scraps of aluminium can often be recycled for front panels. The laminate is also moderately scratch resistant and can be easily cleaned with a damp cloth. I have attached pictures of a bench power supply and pantry transmitter which have been given the laminated fascia treatment. I usually use Open Office 'Drawing' to produce the fascia design.
Rod |
26th Oct 2014, 6:44 pm | #12 |
You can get matt and textured laminating pouches too.
26th Oct 2014, 10:55 pm | #13 |
My approach to printng whole panel legends is to use OHP transparency film. If printed in reverse, the image is protected, and the edges are easily disguised by trim of some sort.
27th Oct 2014, 8:10 am | #14 |
