Old 5th Jul 2017, 5:22 pm   #1
Biggles
Default Easy way to measure battery supply current.
I can't claim originality for this idea but if you need to measure how much current a set is taking from it's battery, solder wires to either side of a small piece of double sided PCB, and insert it between cells in the holder. Current can then be easily measured with an ammeter connected to the free wires, as the PCB breaks the circuit, enabling a series measurement to be made. It may be necessary to build up the connections with a blob of solder to ensure a good contact with the cells.
Alan.
Biggles is offline
Old 5th Jul 2017, 6:12 pm   #2
David G4EBT
David G4EBT's Avatar
Default Re: Easy way to measure battery supply current.
Like this:
http://www.vintage-radio.net/forum/s...attery+current
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 5th Jul 2017, 7:07 pm   #3
Yes, a good old trick well worth re publicising. You can use ali foil and paper for those thinner places like button cells.
Old 7th Jul 2017, 12:06 am   #4
Tim
Tim's Avatar
If your set has an easily accessible on off switch, just connect your ammeter across it when in the off position.
Tim is offline
Old 7th Jul 2017, 8:52 am   #5
Tricky to measure the "high volume" current with a combined vol/on/off control!
Old 13th Aug 2017, 1:00 am   #6
Tim
Tim's Avatar
"Tricky to measure the "high volume" current with a combined vol/on/off control"
Yes true, but it's a good trick to measure the normal current and to verify the set isn't taking too much, such as for a short battery life fault.
Something I have done in the past is to connect the ammeter to two small squares of kitchen foil, each stuck to opposite sides of a piece of card or thin plastic, a 5 minute make version of the old trick above.
You can slide that in between two of the batteries, which will then obviously connect your meter in. Of course with a PP9 or whatever, you can connect the meter in at the battery clip.
Tim is offline
Old 13th Aug 2017, 10:15 pm   #7
Phil G4SPZ
Phil G4SPZ's Avatar
Now that I have a decent variable-voltage power supply with variable current limit and twin meters, I tend to use that. However, in the field the current probe described is a great idea. I first saw it mentioned in 'Sprat' magazine back in the 1980s but it probably originated long before then!
Phil
Phil G4SPZ is offline
