2nd May 2017, 10:57 pm | #221 |
Re: Calling Hacker Hunter owners!
Hi Mark
Due to a failure of the PC that had the pictues etc it may take me a while to recover the original info. As far as I know the info was correct and the set showed no signs of being altered. Will confirm when I find the original pics Cheers Mike T
2nd May 2017, 10:58 pm | #222 |
Hi Kevin,
Thanks for those details. Just a few things to check: It presumably is a "VHF Hunter" rather than a "Hunter fm/am"? No Royal Warrant? The tone control knobs sound wrong - for that age, they should be the all-silver type - for an example, see here: http://www.vintage-radio.net/forum/s...7&postcount=48 - the only black visible is just a small "skirt" at the bottom. For reference, I've found an image of the later-style knobs: https://www.picclickimg.com/00/s/MTA2NlgxNjAw/z/m0gAAOSwSypY873b/$/Hacker-Hunter-VHF-AM-LW-Radio-With-Power-_57.jpg Those didn't come in until around 65,000. I'm also assuming the the 3 buttons are the same as shown in both those images? Thanks in advance, Mark |
2nd May 2017, 11:00 pm | #223 | |
Cheers, Mark |
2nd May 2017, 11:08 pm | #224 |
Yes it says Hunter and just below the R is says VHF.
No royal warrant. Tone knobs are knurled aluminium on top and a black ring at the bottom as per first pic link. Buttons are black with aluminium insert as per pic. I daren't post a pic as I have been using it in the kitchen over easter and it's filthy.
Kevin |
2nd May 2017, 11:31 pm | #225 |
Thanks, Kevin - that's all as expected. Your set is now in my records
19th May 2017, 5:50 pm | #226 |
Hi Mark,
Two further Hunter details from me, No1 Hacker Hunter RP38A VHF Serial number 30931 Gold Elac Speaker Silver bass and treble knobs Single piece handle Scale print in white and green Grill mesh aluminium Input socket yes Black enamel and chrome badge No royal warrant. No2 Hacker Hunter RP38A VHF Serial number 55596 Gold Elac speaker Silver bass and treble knobs Single piece handle Scale print all white Grill ally with black stripes Input socket yes Black badge with ally highlights and surround No royal warrant. Regards, David. |
19th May 2017, 7:28 pm | #227 |
Hi Mark
Yes it has an insert in the handle and looking at the buttons they do look all metal so apologies for the errors. I still have not managed to recover the original picture but there are some in this thread here http://www.vintage-radio.net/forum/s...ghlight=hunter Hopefully that will confirm it Cheers Mike T
22nd May 2017, 3:47 pm | #228 |
Hi Mike,
Many thanks for confirming that - I've updated the records accordingly. It's nice to have some earlier sets recorded, as we're a bit short of those. All the best, Mark |
22nd May 2017, 3:48 pm | #229 |
24th May 2017, 10:06 am | #230 |
Hi Mark,
My Hunter details Hacker Hunter RP38 VHF Serial number 12186 - stamped into upper chassis? Gold/grey Elac Speaker Silver bass and treble knobs Single piece handle Scale print in white on black Grill mesh aluminium Input socket yes Black enamel and chrome badge No royal warrant. |
24th May 2017, 4:44 pm | #231 |
Thanks for those details - one of the later RP38 sets that I have on record. However, I do have a few questions: 1. Regarding the "Input socket", are you sure that's a DC input socket, and if so, does it look original? It might be a dealer-fit job - it seems that Hacker offered a kit to dealers for this purpose - the clue seems to be that the aluminium trim is rectangular rather than round. 2. As for the badge, I would expect a set of this vintage to be lacking a separate badge; the Hacker logo being embossed in the grille. 3. Is the set finished in teak, or black Rexine? And does the handle come with a matching insert? It's entirely possible that the chassis has been transplanted into a newer case. The separate badge started at approximately 17,500, and the DC input socket arrived a bit later at ~30,000. So, it's entirely possible the "donor" set did come with the DC socket - that might be apparent from examining the wiring. All the best, Mark |
24th May 2017, 6:31 pm | #232 |
There's also the little matter of the bass and treble knobs - if it has those it's surely an RP38A.
Paul |
26th May 2017, 10:32 am | #233 |
No Longer a Member
Hi Mark,
Here are details for the Hunter I've just finished restoring: Model RP38A - "Hunter fm-am" S/N - 66492 Handle type - three piece Grille type - extruded aluminium, black/silver stripes. Scale print - white only DC input socket - fitted Loudspeaker type and finish - unpainted Elac Tone control knobs - black plastic with silver tops and bases I've attached a few photos as well. As it's my first Hunter, I have a couple of questions to ask... Firstly, there is a bit of a gap between the top of the front panel and the chassis, so much that you can just see the screws that hold the silver trim panel in place. Is this normal? Second, it's impossible to get the volume down to zero, there's always something there once you've turned the control far enough round to switch it on. I'm guessing this is normal too, as it was like that before I dismantled the pot to clean and lubricate it. It was very twitchy (but not crackly!) before I attended to it. Cheers, Dave |
26th May 2017, 2:25 pm | #234 |
No Longer a Member
Hello again!
I forgot to mention this earlier, but there's a hand-written label on the track side of the PCB with "18/9/75" written on it. That makes it about four months older than I am! Unfortunately I didn't take a photo of the label while I had the chassis out.... Cheers, Dave |
26th May 2017, 3:09 pm | #235 |
Hi Dave,
Thanks for those details - that looks like a pristine example of the latest variant of the Hunter. Nice restoration job Yes, sometimes there is a gap. Perhaps the tolerances of the handle holes in the side aren't always what they could have been? Perhaps the holes could be "eased" slightly to allow the chassis to move forward slightly? And yes, often the volume doesn't quite go down to zero. But if the potentiometer is otherwise good, it's best to live with it. A modern replacement would solve that problem, but would be plastic, and not so easy to fit. Usually, I repair rather than replace Hunter volume controls. Thanks again, Mark |
26th May 2017, 5:43 pm | #236 | |
The Hacker name on the front is in a silver black filled embossed a bar below the mesh. There is an aerial socket on the left side as you look at it and another socket on the right which has blue, green, red and black wires from it these separate and the blue and black wires go to a power circuit via mini banana plugs and the red and green wires go to the speaker. You may well be right re the retro-fit as the back of the socket has shrink-fit black covering. |
26th May 2017, 6:00 pm | #237 |
26th May 2017, 6:51 pm | #238 |
OK, that makes a bit more sense
The socket on the right is for headphones, so not a DC input. And it will be original. So that only leaves the question about the case and handle: teak or black Rexine for the case, and is there a matching insert for the handle? Cheers, Mark |
27th May 2017, 8:00 am | #239 |
Hi Mark
A couple more to add: RP38A Hunter VHF Serial no. 44781 extruded aluminium grille one piece handle dc input socket pressed aluminium badge teak sides with slightly rounded corners gold elac speaker RP38A Hunter fm-am Serial no. 60617 extruded aluminium grille 3 piece handle dc input socket pressed aluminium badge teak sides with squarer corners gold elac speaker royal warrant smoother rexine covering than the other (seems to be a softer material with less grain - a bit like the roberts stuff) Rear grille missing I'm surprised that they still have light, third and home alongside 2,3 and 4 on the dial - very patriotic Gavin |
27th May 2017, 8:20 pm | #240 | |
No Longer a Member
I must admit I'm pleased with the way it's turned out. To be fair it was in reasonable condition when I got it. I had a pretty good idea that under all the dust, muck and perished foam there was a good radio waiting to get out. The only big jobs besides cleaning and polishing were refurbishing the volume pot and polishing up the dial plate, which was quite badly scratched. The Novus has done the trick there... it's not cheap but it works! I also had a dent in one of the aluminium handle caps, and was pleased to discover that the tip of the handle of my terminal screwdriver was exactly the right size to push the dent out from the inside. It's saved me from having to go begging for another cap. There's still a couple of small marks on the volume and tuning knobs but I can live with that. I've definitely got a taste for Hackers now, they are just so much better thought out than Roberts radios ever were. The next one on the bench will be the Autocrat that's in the post right now. It sounds like all it needs is some AF117's and a good clean.... we shall see |
