Old 21st May 2017, 3:15 pm   #1
Julian67
Default Hitachi TRK-8600E cassette recorder not working
Greetings,
Just bought an Hitachi TRK-8600E cassette / radio recorder but the cassette recorder does not work. All I get when I press PLAY / FAST/Back is a sharp whiring sound. When I press RECORD + PLAY, the RECORD button will not press in.
I open the cassette case and tried to move the black wheel up (looking in), on the right. Does not move.
Then I tried to remove the back by loosening the screws: 4 top
2 (above the electric cord)
2 at the bottom
but unable to remove the back plastic case. Bottom is lose but not the top.
Would anyone tell me what I'm doing wrong in trying to remove the brown back case ?
And, when I remove the back, what to check to get the cassette recorder working?
Or, what the problem is?
Many thanks
Julian67 is offline
Old 21st May 2017, 3:23 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Advice: Hitachi TRK-8600E cassette not working
The belts are probably knackered.
paulsherwin is offline
Old 21st May 2017, 6:14 pm   #3
Andrew2
Andrew2's Avatar
Paul is almost certainly correct. After many years of resting, the belts often turn to black 'goo' and fall off and/or stick to the pulleys etc.
The record key refusing to press probably means that the cassette has had the 'record protect' tab removed. Is the tape a commercial pre-recorded music cassette? If it is, then that's the cause. They were protected against erasure by having no tab.
The back may simply be stuck after so long. Quite often the mating edges had a fabric strip glued along them to stop the case rattling when the music is turned up loud. After so long, the glue can end up stopping the case being taken apart.
Gentle brute force may be in order, but not before checking for hidden screws or perhaps the batteries getting in the way?
Andy G1HBE.
Andrew2 is offline
Old 21st May 2017, 8:50 pm   #4
paulsherwin
Check for a screw in the battery compartment.
Old 21st May 2017, 9:20 pm   #5
ben
ben's Avatar
Default Re: Hitachi TRK-8600E cassette recorder not working
Have you removed any knobs on the sides? maybe also the antenna.
Your whirring almost certainly means the rubber drive belt has snapped. Usual procedure is thread a piece of string round its path to get a rough idea of length. Alteratively buy a mixed pack of belts off Ebay and hope there's one to suit!
Regards,
Ben.
ben is offline
Old 23rd May 2017, 8:44 am   #6
Julian67
Greetings
Thank you friends for taking the time to reply sharing your suggestions. Much appreciated.
Keep well
Julian67 is offline
Old 29th May 2017, 3:29 pm   #7
Julian67
Default Hitachi TRK-8600E cassette recorder snappedmotor belt
Hi
I removed the back cover and discovered the motor (part no: 5577082 - 10807-A) rubber belt has snapped. The motor just whirls, so I assume it's ok.
Would anyone have a pic of how to attach the belt to the cassette part?
Where could I source a new belt?
Based upon a snapped belt and whirring motor, do you think the motor is ok?
A photo + description on how to attach the belt would be great for this novice!
Many thanks
Julian67 is offline
Old 29th May 2017, 5:45 pm   #8
toshiba tony
toshiba tony's Avatar
You are only in with a chance if you post a pic of the deck, from the belt end of course.
toshiba tony is offline
Old 29th May 2017, 6:11 pm   #9
Chris55000
Hi!
What little technical data there is appears to be "the-cough-up-for" variety, but I've managed to get this little collection from a Russian "Audio Bygone's" site - is it any help?
Chris Williams
Chris55000 is offline
Old 31st May 2017, 6:49 am   #10
Julian67
Default Hitachi TRK-8600E cassette recorder motor belt fitment
Greetings,
I removed the rear panel and traced the whirring sound to the motor (part no: 5577082 10807-A) where I discovered the motor belt was snapped.
QUESTIONS:
Would anyone know the correct belt size and where I could source one cheaply?
Steps on how to fit it + possibly a pic of the correct fitting?
Being a novice, I'm not sure where it feeds through from the motor to the cassette wheel underneath.
Many thanks in anticipation.
Julian67 is offline
Old 4th Jun 2017, 6:20 pm   #11
crackle
Why not take a photo of what you are seeing and post it in a thread here so we can see it, then we may be able to advise.
Mike
crackle is offline
Old 5th Jun 2017, 7:03 pm   #12
Julian67
Hitachi TRK8600-E pics attached
ID:	143995   Click image for larger version
Julian67 is offline
