17th May 2017, 9:18 pm | #21 | |
Re: Correcting Oscillscope Trace
I (seriously) don't think you can better a DS1054Z for value-for-money, it really does punch way above its weight and I'd recommend it for someone looking for a new scope at the budget end of the market.
Chris |
18th May 2017, 12:44 pm | #22 |
Correcting oscilloscope trace.
It would help to identify the model if you post a photograph. It sounds like a Crotech. Philip Harris were school suppliers who re-badged equipment, as also did Griffin and George. Crotech were sold under Harris and Gould names. It is probalby not a Scopex model, as they were rebadged and sold by Avo and also I think Racal. Your tube number is not complete. It should be D14-xxx/GY.123. I expect it will be D14-363, by Philips/Mullard/Herleen. 1985 to 2006. Do not scrap the tube quite yet. Your fault is what was called trapezium distortion years ago. It could be caused by incorrect voltages on the tube and the deflection plates. If you cannot locate a manual, I have data sheets on various CRTs which will give you the likely tube operating voltages once we have identified the type. Have you checked the voltages around the whole circuit? You do not say, but does the distortion come only on Channel1? If you align the trace horizontal at the top of the screen, what happens when you move it to the bottom? I endorse what mikehennessy says. An analogue scope is much easier to "drive" and to learn upon. And to service and keep working. I use an analogue scope most of the time when fault finding on radio and test gear as it is quicker to change ranges. And for alignment with a wobbulator, I find an analogue storage much preferable, as it is easy to set to avoid flicker while giving a fast response. I use a Telequipment DM63, which I know mikehennessy likes. I prefer it to a HP1741 which they have tried to make fool-proof, and this fool finds difficult to use. wme_bill |
18th May 2017, 1:26 pm | #23 | ||
Another nod towards the Telequipment scopes. I've had a D83, a D61 and an S61 over the years. The D83 was a marvellous scope.
Second to that is Philips analogue units. Well documented, literally made of jellybean parts, well engineered and nice and cheap Quote:
18th May 2017, 8:12 pm | #24 | |
Here is a picture of the 3305 oscilloscope, not the best picture but I couldn't find much for it on the web and the newer version (can't quite read the model no.) from the Philips Harris website. David |
18th May 2017, 9:03 pm | #25 |
Educational instrument purchasers have different priorities to the market outside education. The equipment made for them is designed to demonstrate things rather than go into the difficult applications. They are intended for beginner's lab sessions for people learning what a scope is and to learn the basics of using one. The people in the university needing to use one in anget will have something heavily discounted from Tek or keysight to get serious with.
