Old 6th Aug 2017, 3:25 pm   #1
mole42uk
mole42uk's Avatar
Default D34L30-A ICs - what are they?
I have discovered some new D34L30-A ICs in my store today but I have no idea what they are. There are some D3230A chips as well.
Can anyone identify them?
Thanks
Richard
Index:
mole42uk is offline
Old 9th Aug 2017, 8:24 am   #2
pbengtech
Default Re: D34L30-A ICs - what are they?
None of my equivalent books are any help, could you please post a picture of them?
I need to see the number of pins and the manufacturers logo...
Thanks,
Phil
pbengtech is offline
Old 9th Aug 2017, 1:02 pm   #3
Sideband
Sideband's Avatar
They may be 'in-house' numbers....in other words, standard IC's but re-numbered by a manufacturer. Thorn did this a lot. If we know the manufacturers logo, it might be possible to track down an equivalent.
Sideband is offline
Old 9th Aug 2017, 5:45 pm   #4
mole42uk
mole42uk's Avatar
Here is a photo of the mysterious beasts....
Richard
Index:
mole42uk is offline
Old 9th Aug 2017, 8:45 pm   #5
AC/HL
AC/HL's Avatar
The two top right are Motorola. They all appear to be ceramic packages, so better quality parts.
AC/HL is offline
Old 9th Aug 2017, 10:03 pm   #6
Radio Wrangler
Radio Wrangler's Avatar
The Motorola ones also have Motorola's usual typefont. For some reason the lower row make me think of Natsemi or SGS
Radio Wrangler is online now
Old 10th Aug 2017, 6:09 am   #7
mole42uk
mole42uk's Avatar
There's a little voice in the recesses of my head says RAM, possibly each chip is 1x8k. That might fit with my old NASCOM II but.
I've just remembered that the file of 80-BUS paperwork isn't too deeply buried, I'll have a look in there.
There's some TTL on the foam pad as well, so I might have been gathering parts for a memory board.
Richard
Index:
mole42uk is offline
Old 10th Aug 2017, 9:05 pm   #8
Skywave
Arrow Re: D34L30-A ICs - what are they?
A quick perusal around the 'Net revealed that the D3430A was manufactured by Texas; the D34L30A manufactured by Ferranti. Noting found for the D3230A.
One wild thought did cross my mind: if in "D3430A" we replace the "D3" by "7", we get 7430A: TTL chip. "D" is the fourth letter of the alphabet and "3" is . . . 3. Now 4 + 3 = 7. Hmm.
Just a one-off, inspired & a totally bizarre thought . . . . .
Al.
Skywave is offline
Old 10th Aug 2017, 9:57 pm   #9
Bill
The lower ones are Ferranti low power CDI(Collector Diffused Isolation) versions of TTL=7430. Pretty sure from the date codes, 1975,1976 that they were destined for "Post Office" System X phone exchange equipment. A couple of years earlier we were making thousands of these and similar for this contract. There was a further stage in production when the devices got a "Conformal Coating" of varnish on the package. Skywave Al is on the right track. Edit to add , I see the varnish is already on , the blue stuff.
Bill is offline
Old 11th Aug 2017, 6:18 am   #10
mole42uk
mole42uk's Avatar
Thanks Bill, it's good to know what they are. I'm not sure where I got them from, I remember going for an interview at Ferranti in Manchester around 1971 but I wouldn't have gained some unusual parts as a reward!
Richard
Index:
mole42uk is offline
Old 11th Aug 2017, 4:54 pm   #11
Skywave
Question Re: D34L30-A ICs - what are they?
Following my post #8 and the remark made by Bill in post #9, I just wonder if the D3230A might be Motorola's version of an SN5430.
Perhaps the D prefix in D3430A and D3230A simply signifies 'digital'?
Moreover, is my 'signature' below applicable to all of these mutterings of mine?
Al.
Skywave is offline
Old 11th Aug 2017, 5:48 pm   #12
mole42uk
mole42uk's Avatar
So, does anyone know of a System X preservation society that could use them? The only PO people I know are the ones that run the uniselector exchange at Avoncroft.
Richard
Index:
mole42uk is offline
Old 11th Aug 2017, 6:26 pm   #13
You could pop the lid off one of the ceramic ones (large sidecutters applied to the join) and have a look at the chip.
Old 11th Aug 2017, 8:36 pm   #14
Bill
Yes, I may have signed it
We've already established the identity so it seems a bit destructive just to see a bit of modified sand.
The ceramic packages "Cerdips" were a lot more expensive to produce than the plastic DILs.
IIRC the 54 range of TTL had a wider operating temperature range than 74 so was more expensive. We were making tons of "normal" TTL just after those blokes landed on the moon in 1969, not sure if there was a connection there.
Bill
Bill is offline
