6th Jul 2017, 7:04 pm | #1 |
TDA2030 + Baxandall audio amp circuit
Hi - following on from a conversation on another thread I have attempted to make my own audio amplifier circuit from scratch.
I want tone control included to have based it on the Baxandall circuit following the description on this website. http://www.learnabout-electronics.or...plifiers42.php I have used a TDA2030 as the amplifier chip and have added a log pot at the front end for volume control and a 1000uF capacitor at the output to feed into an old 4ohm speaker (note in the photo is says 10uF but it is now 1000uF). I am using a 12V power supply. Its not working!! I have checked all my solder joint etc and can see nothing wrong so am suspecting my circuit design is wrong. Can anyone spot where I've gone wrong. Here is my circuit diagram: Many thanks, Nicola |
6th Jul 2017, 7:23 pm | #2 |
Re: TDA2030 + Baxandall audio amp circuit
First thing is to check the output pin of the chip for half supply volts. If this is at full rail or 0 volts then you have a problem. Check the voltage between 0 volts (negative) and the pin of the chip which goes to the output capacitor connected between it and the loudspeaker. Instability i.e. supersonic oscillation can also cause funny things to happen. If the output pin is sitting at about half supply volts, then maybe you have a signal connection problem, maybe open circuit speaker or audio input connectors? Edit; Just noticed that the output capacitor is a bit on the small side. Something like 470-1000 microFarad would be better.
Alan. |
6th Jul 2017, 8:03 pm | #3 |
I would first get the amplifier working without the tone network if you can as per the schematic shown at Fig17 in the 1st link below, you can use your existing 50k volume pot in place of the 22k volume pot shown on that schematic, if you can get the amp working as per that schematic and all's well then I would connect up the passive Baxandall network (4.2.2 in the 2nd link below) The Baxendall's input connected to the wiper of the volume pot and the Baxendall's output connected to C1 -ve (C1 in Fig17 of 1st link) The top of the volume pot being the signal input, Baxendall network ground connects to amplifiers ground, then see how it responds:
http://www.st.com/content/ccc/resour...CD00000128.pdf http://www.learnabout-electronics.or...plifiers42.php Lawrence. Last edited by ms660; 6th Jul 2017 at 8:18 pm. |
6th Jul 2017, 8:58 pm | #4 |
6th Jul 2017, 8:59 pm | #5 |
Good idea - I will build a new one without the Baxandall.
In my circuit I used the active Baxandall design where its ground connects to the chips output rather than actual ground. Have I misinterpreted the active Baxandall. I've just connected a loudspeaker to its output. Should I instead connect an amplifer circuit as in the TDA2030 specs? That might be why the active Baxandall only has a 10 uF cap at its output because it is not designed for a loudspeaker connection. That first chip is simply to reduce the loses due to the Baxandall. Last edited by indigo.girl; 6th Jul 2017 at 9:07 pm. |
6th Jul 2017, 9:16 pm | #6 |
Sorry, but you can't strap a Baxandall network around a TDA2030.
The TDA2030 must be used in a circuit with with a minimum gain of x16. At values below that, it won't be stable. To achieve that, you could use a feedback resistor of 22k, and 1k2 to ground (via a capacitor of around 22uF). So yes, the tone control circuit needs to be implemented with a separate op-amp. Make sure it's one that is unity-gain stable. I'd also add a unity gain buffer between the input and the tone control circuit. Dual op-amps are very handy... The NE5532 is the classic audio op-amp, but is overkill for a TDA2030-based amp. I recommend the LM833, but there are countless options out there You can put the volume control between that and the TDA2030. But if you did add the buffer in front of the tone control section, then the volume pot could be placed at the input if you like. |
6th Jul 2017, 9:19 pm | #7 |
Remember ideal op-amp behaviour: (1) no current flows into or out of either input, (2) If the output can assume some voltage that would cause the difference between the + and - inputs to be zero, it will do that; otherwise, it will hit the positive supply rail if the + input is higher, or the negative supply rail if the - input is higher.
The only place any current flowing into the input of your circuit can go, is into the amplifier output. If you have something like Circuit input ----- resistor R1 ----- amplifier - input ----- resistor R2 ----- amplifier output then the amplifier - input will be at 6V, and the current through R2 will be equal to the current through R1. You can work the current out from the input voltage divided by R1 (pretend the coupling capacitor never charges or discharges, just always has a steady 6V across it, and try not to think too hard about how it can have a voltage across it if we've just said it never takes a charge), and that multiplied by R2 will tell you the difference between what voltage at the amplifier output must be and 6V. Now you can see that if we let the current through R1 and R2 be I, then I = Vin / R1, so Vout = 6 - I * R2 = 6 - Vin * R2 / R1. So the gain is set by R2 / R1, and it relies on there being a DC path from the output to the inverting input. That tone control circuit in the input looks like it could be creating some strange values for R1 and R2. Try and get the TDA2030 to amplify (and not oscillate!) without it, first .....
6th Jul 2017, 9:38 pm | #8 |
Following on from that, if it helps, there's an introduction to op-amps here: http://www.markhennessy.co.uk/articles/op-amps.htm
6th Jul 2017, 11:05 pm | #9 |
Re post#4. Yes, that is too low for the output pin to sit at IG. The general rule of thumb (but not always, depending on the type of circuit) is that the output pin should be at half supply volts. This is to ensure that the output can swing between near 0 volts and maximum supply volts, hence giving maximum power out. Also beware that some amplifier chips are bridge types, which means that the output terminals both sit at half supply volts, with the speaker connected between them, and you will damage the chip if either of the speaker wires touches 0 volts. This is particularly common with car radio types. The chip you are using is not a bridge type.
Hope that helps. Alan. |
7th Jul 2017, 9:23 am | #10 | |
7th Jul 2017, 9:47 am | #11 |
Using a single supply you need a cap between the 4.7K resister earthy end and earth (ground)
7th Jul 2017, 10:01 am | #12 |
Hi Nicola, if you do a little thought-experiment you can see that 196V is impossible, - fortunately, from a safety viewpoint!
It's a 14W max device from a 12V rail. Let's for simplicity assume it's handing 10W for the time being. A Watt is a Volt x Amp. So you'd expect 1V out with 10A current =10W by one combination of volts and amps. But this doesn't seem remotely likely for various reasons- that would require very beefy circuit board tracks to provide a low-impedance pathway. So how about 10V out with 1A current =10W? This seems much more likely! ...or a cocktail of each in between. How did you get those current and voltage calculations? You do seem to be confusing the DC operating conditions (as set by your resistive voltage divider) with the AC circuit
Al Last edited by Al (astral highway); 7th Jul 2017 at 10:16 am. Reason: To avoid confusion |
7th Jul 2017, 10:32 am | #13 |
Which causes the TDA2030 to have unity gain at dc so its output doesn't slew hard over and an ac gain in the audio region of 1+(150/4.7).
7th Jul 2017, 11:31 am | #14 | |
In many ways, split supplies are much easier for someone who is still new to all this. But even so, the cap in series with the 4k7 is still very much recommended. In terms of value, it's not critical. 4u7 would be adequate, anything more is a bonus. Nice little chips, these. Shame they went obsolete - I've no idea who's making them today. I'm guessing that Cricklewood have them as NOS? There's quite an industry in making fake chips - even ones as cheap as the 555: https://zeptobars.com/en/read/Ti-555...-china-chinese |
7th Jul 2017, 12:13 pm | #15 |
Also, it's probably wise to have a supply decoupling capacitor with low HF impedance connected as close as possible across the IC's supply pins- particularly if the supply leads are long. 220-470nF plastic film should do. Many of these power op-amp type ICs don't need too much excuse to misbehave!
7th Jul 2017, 2:17 pm | #16 | |
This is the actual circuit I am building from the spec sheet: However, I forgot the realise that the cap in series with the 4.7K will block DC and so I have applied the gain of the TDA2030 to the DC component hence the 196V calculation. I can see now that for the DC there is a unity gain: Vin+ = 6V = Vin- = Vout But for the AC audio component there is a 32x gain due to the 4.7K:150K resistor pairing. All the above comments helped me get there so thanks to everyone |
7th Jul 2017, 2:28 pm | #17 | |
7th Jul 2017, 2:47 pm | #18 |
Have I got this right Turret slug? Or did you mean a cap from 12V supply to pin1 and another from 12V supply to pin2?
It doesn't make sense to me to have the two input pins connected by a cap so I think I have misunderstood your suggestion. |
7th Jul 2017, 3:20 pm | #19 |
Connect the decoupling capacitor between pin 5 (12v +ve) and Pin 3 (12v -ve which is ground)
EDIT: All as per Fig 17 schematic in the data sheets (page 8) The reason for it being there is given in Table 6 (page 11) Table 6 also shows what can happen if the values given for other components are changed. Lawrence. Last edited by ms660; 7th Jul 2017 at 3:32 pm. |
7th Jul 2017, 3:29 pm | #20 | |
(The supply decoupling cap is already there (circled in yellow) Last edited by indigo.girl; 7th Jul 2017 at 3:35 pm. |
