16th Dec 2014, 2:14 am | #21 |
Re: Murphy V240C Any help whatsoever.
As far testing the CRT is concerned, an interesting suggestion from JohnHKS is to consider the grid and cathode of the tube as a diode. The grid and leads are removed for this test. Supply the correct heater voltage to the CRT which for the Mazda CRM141 is 12.6 volts, leave the tube running for a while. Using a multimeter switched to the resistance range connect the meter to the grid and cathode pins. If the CRT has any emission this will be indicated as a meter reading. The internal battery supplies the necessary voltage for the conduction test. If there is no reading, reverse the meter leads and try again.
I have never tried this procedure but I'm certain it works. A few words of caution. The correct heater voltage for the CRM141 is 12.6 volts but some rebuilt tubes were occasionally fitted with 6.3 volt gun assemblies. DFWB. |
16th Dec 2014, 3:07 am | #22 |
Thanks DFWB
16th Dec 2014, 10:55 pm | #23 |
This is a rough test for 'some' emission. If reading as David has suggested it is likely to produce a picture and may well be OK but not of course a reading of quantity or quality of emission. Makes a good test for an unknown tube and is completely harmless. John.
17th Dec 2014, 11:57 am | #24 |
This is exactly the method used by all Taylor valve testers in conjunction with the CRT adapter.
Stephen _________"It`s only an old telly" ___ |
21st Dec 2014, 11:03 pm | #25 |
That book arrived yesterday DFWB, very informative reading but will be a lot better when I have read and understood it a few times. I am now trying to find the same books on the Bush TV22s a b c, and also hopefully a few books on my radios, many thanks for the heads up DFWB, regards And a good Christmas, Andy
