26th Jul 2008, 9:34 am | #1 |
Correct polarity for capacitor in audio amp?
At this very moment in time, I have a hot soldering iron andreplacing caps in my Wurlitzer jukebox amp. All is going swimmingly at the mo, but I've found what could be an error on the schemetic or the board. The board has + symbols on it to denote the cap polarity, but the schematic shows one of the caps with opposite polarity to the board. It's a stereo amp and there are two caps going to the 'Aux Amp' output. According to the board, the 'minus' of the cap goes to the 'aux amp'output, but the schematic shows one of these caps with the 'plus' going to the output. Surely both caps should be the same way round (one's left channel & one's right) so I'm assuming the schematic is wrong.
26th Jul 2008, 11:04 am | #2 |
Re: Correct polarity for capicitor in audio amp?
I reckon you must be right. They'd have to be the same way round logic would say. But which way is right I'm not sure! I would say the signal should go from + to - but I may well be wrong.
I'd just like to say "Good luck, we're all counting on you" |
26th Jul 2008, 11:12 am | #3 |
Common sense dictates it should be fitted the same way as the original
Mike |
26th Jul 2008, 11:53 am | #4 |
Unfortunately I took the old one out before checking. But I've decided to go with the board markings and have the minus going to the output, which basically makes sense. Anyway, I will know in a few minutes as I am abou to power it up.
26th Jul 2008, 11:57 am | #5 |
26th Jul 2008, 2:12 pm | #6 |
How about showing us the circuit? We can probably deduce from that which way the capacitors should go. It is possible for PCB's to be incorrectly marked.
Rich.
26th Jul 2008, 2:30 pm | #7 |
26th Jul 2008, 3:30 pm | #8 |
Sorry Marky, but the quality of the diagram isn't good enough for me to identify component designations. I've tried "blowing it up", but to no avail. Members with beter eyesight than me may be able to assist.
26th Jul 2008, 3:34 pm | #9 |
Nope, it's far too low-resolution to be of any use. If you have a restriction on size/resolution on your photo hosting (most do), zip a higher-res scan then use "Manage Attachments" to add the .zip file to your post and upload it to the forum. (The forum has a larger file-size limit for .zip files than images.) Ensure that it's possible to clearly read all component designations and values when zoomed in. Cheers, Kat |
26th Jul 2008, 4:50 pm | #10 |
Posted zip file of schematic over at 'powered up my wurlitzer' thread.
26th Jul 2008, 5:06 pm | #11 |
Thanks for uploading a good copy of the schematic Correct polarity for both caps is with the +ve end connected to the PCB track leading to the cathode pin of the valve, the -ve end connected to the PCB track leading to the off-board wiring. The reasoning behind this? The cathodes are shown as being at 10.5V and it's a reasonable to assume that anything connected to the 'aux' output may have a DC path to ground. Regards, Kat |
26th Jul 2008, 5:51 pm | #12 | |
26th Jul 2008, 6:00 pm | #13 |
Now that the polarity of the capacitors has been sorted out it is probably time we closed this thread and continued discussion of this amplifier in this thread;
https://www.vintage-radio.net/forum/...ad.php?t=30699 which is where Marky has posted the relevant schematics. Regards,
Brian |
