29th Aug 2015, 3:27 pm | #1 |
Rewiring valve radio - colours
Originally almost all wires in my CR100 were red rubber coated 6x0.25 and 14x0.2 .
I am going to use silicone insulated flex 16x0.2 . It is available in different colours and I am wondering if there is any standard, anyway I am planning to use: red - for power and anodes purple or yellow - valve heaters + green - to chassis black - cathodes, bias and to the 24 100nf caps orange - for >60V signals blue - low voltage signals white - other (with exception that colours will be the same as in manual, if specified.) Does that make sense or should I change anything? |
29th Aug 2015, 3:37 pm | #2 |
Re: Rewiring valve radio - colours
There's no 'official' standard.
If it was being rebuilt by a Navy workshop or MoD contractor any time after about 1960 they'd use pink PTFE-insulated wire throughout, with coloured/numbered sleeves on the end of each wire to identify function and location. [The PTFE insulation was because old-style PVC insulation gives off corrosive/toxic fumes if it overheats/burns]. |
29th Aug 2015, 3:45 pm | #3 |
Eddystone radios had a preferred colour scheme and possibly HMV.
Have you searched this website for previous posts? |
29th Aug 2015, 6:08 pm | #5 | |
29th Aug 2015, 6:22 pm | #6 |
Thank you all, Apologize for not digging hard enough, but hope it was a good knowledge refresh for all restorers.
I think that the thread can be closed. |
29th Aug 2015, 6:23 pm | #7 |
Here's the ARRL standard:
BLA - grounds, grounded elements, returns BRO - heaters/filaments, off ground RED - power supply B+ ORA - screen grids (and base 2 of transistors) YEL - cathodes (and transistor emitters) GRN - control grids, diode plates (and base 1 of transistors) BLU - plates (and transistor collectors) VIO - power supply, minus leads GRA - AC power line leads WHI - bias supply, B or C minus, AGC Certainly I've seen many amps using a brown twisted pair for heaters. I expect your soldering and cable routing will be a lot more important than the colours! Good luck with it. Cheers, Frank Last edited by frankmcvey; 29th Aug 2015 at 6:28 pm. |
29th Aug 2015, 7:41 pm | #8 | ||
Either way, if I was rebuilding a CR100 with the emphasis on function and future usable-life over mere appearance, I'd have no ethical issues in using PTFE/ETFE wire, because that's what they'd have used in Navy [and Marconi] workshops from the late-1950s onwards. I've seen at least one early-1960s rebuilt-by-REME AR88D with pink wire! |
29th Aug 2015, 7:49 pm | #9 | |
29th Aug 2015, 8:47 pm | #10 |
With the exception of A.C. power wires, the coding that Frank has specified in post #7 is the one I use when wiring - or rewiring - equipment.
Al. |
29th Aug 2015, 10:01 pm | #11 |
I also follow Frank's standard. The ARRL handbook is easy to get in Aust.
RSGB handbook is like hens teeth!! Joe |
29th Aug 2015, 11:12 pm | #12 |
30th Aug 2015, 6:20 am | #13 |
I speak and write poorly!!! as you have pointed out! ( previously)
Somehow I understand the English method better English presentation and diagrams are far better than those US derived. Howard W Sams is an example!! MANY thousands of circuit diagrams available, BUT parts listed as "For 6L6 PP ", doesnt even mean much to me !! Coils are "mostly" hand wound in RSGB handbooks, making it "easy" to copy. American publications listing a coil/transformer/IF, as BA2846429862598261 isnt useful!! PLUS if I can buy it from Eblech, its $1000 plus the cost of the origional part. I must be getting old :-( Best regards to all Joe |
