9th Oct 2015, 11:21 am | #21 |
Re: Blaupunkt Potentiometer
Great idea!
"Saving Radiograms one gram at a time" |
9th Oct 2015, 2:50 pm | #22 | |
Steve
10th Oct 2015, 2:38 am | #23 |
Drilling out the rivets shouldn't be too damaging. You can either use a thin drill and hope to break up the metal "walls" from the inside, or use a fat drill to break up the head -- if you do this, it will only take a few turns; so either use a variable speed cordless drill, or just hold the drill bit in your hand and rotate it.
You can easily get nuts and bolts down to 2.5 and even 2 mm., and even smaller sizes from specialist suppliers; so holding it all back together when it's freed up won't be a problem.
10th Oct 2015, 6:35 am | #24 |
I've had a look to see if I could find you a pot, but the one I found is different to yours.
Good luck with the tear-down, Andy.
10th Oct 2015, 8:52 am | #25 |
Thanks Julie and thank you for looking Andy..... :0)
