Old 25th Jun 2017, 11:23 am   #1
SeanStevens
SeanStevens's Avatar
Default Bell Set No 20 X2 - What exactly did they do?
Hi, I have two Bell Set 20's here:
What / how were they utilised?
Were they just an additional ringer?
Oh and there is a little phone without a dial - would that have been used in conjunction withe the bell set?
Thanks
SEAN
ID:	145054   Click image for larger version
ID:	145055   Click image for larger version
There are only 10 types of people, those who understand the binary system, and those who don't.
SeanStevens is offline
Old 25th Jun 2017, 12:49 pm   #2
Pellseinydd
Default Re: Bell Set No 20 X2 - What exactly did they do?
They were like a mini switchboard which could have one or two extensions. Used mainly as a 'manager/secretary' set up with the secretary having the 'main phone connected to the Bellset 20 and the 'boss' as the extension. The generator was used to ring the extension/s. Note how the two extensions were individually called by means of a pressbutton being pressed whilst turning the generator at the main phone to call. The two extension Plan 5 was only available between phones within the same building. The extension on a Plan 7 could be the other side of the town!
They were known as Extension Plans 5 (for two extensions) and a Plan 7 for a single extension. See attached photos of GPO 'N' diagrams for the arrangements.
Note that the earlier version of the Bellset that preceded the BS 20 only had a three position switch.
The extension/s could be fitted with a dial to dial out when switched through to the exchange line. The 'little telephone without a dial' isn't one that would have been used as an extension. A standard issue GPO phone as per the relevant 'N' diagram would have been used.
ID:	145060   Click image for larger version
ID:	145061   Click image for larger version
Pellseinydd is offline
Old 25th Jun 2017, 8:09 pm   #3
SeanStevens
Many thanks - a perfect explanation
SEAN
