Old 16th Sep 2017, 8:02 pm   #1
bart1963
Default Murphy U198m
Hi
I have a Murphy U198m all looks good but 2 of the lugs on the mains dropper resistor have snapped off.
Part no 63574
R21 944 ohm
R22 168 ohm 5% 25w
R23 160 ohm
can anyone help with a replacement or alternative fix.
Thanks
Bart.
bart1963 is offline
Old 16th Sep 2017, 8:18 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Murphy U198m
What exactly do you mean when you say the lugs have snapped off?
Your main options are:
1. Mend the existing dropper
2. Replace it with another dropper from a scrap set
3. Modify the radio to use a capacitor dropper
4. Modify it to use a diode dropper
The dropper is a standard value and many members will have one in the junk box. For basic info on a cap/diode conversion see this old article by Paul Stenning: http://www.vintage-radio.com/repair-...per-calcs.html
paulsherwin is offline
Old 16th Sep 2017, 8:40 pm   #3
bart1963
The Tabs/ lugs the wires connect to have snapped with only a small piece of lug remaining not enough to attach wire to.
Thanks for your help.
bart1963 is offline
Old 16th Sep 2017, 10:05 pm   #4
Boater Sam
Wrap a small hose clip around the dropper at the tag position to get a contact.
Boater Sam is offline
Old 16th Sep 2017, 10:16 pm   #5
paulsherwin
Yes, you should be able to replace it with a Jubilee clip. I think Poundland sell them.
Old 17th Sep 2017, 4:51 pm   #6
bart1963
ok thanks will try latter thanks for the help.
bart1963 is offline
Old 19th Sep 2017, 7:19 pm   #7
bart1963
Just an update got radio working. Thanks for all your help just need to re cord tuner then put it back in case and give it a good polish.
bart1963 is offline
Old 19th Sep 2017, 7:23 pm   #8
paulsherwin
These radios work well once sorted out, though my U598 (U198 in a fur coat) has a bit of modulation hum.
Old 19th Sep 2017, 7:40 pm   #9
bart1963
Thanks again for your time I am new to this hobby so its a steep learning curve do you know of any good books for me to read.
bart1963 is offline
Old 19th Sep 2017, 8:03 pm   #10
paulsherwin
Lots of useful stuff here, though some of it is a bit dated and you may find it daunting at first.
