Old 28th Mar 2015, 11:00 pm   #1
saxmaniac
Default Ferrograph pinch wheel
I have just got a series 5 Ferrograph into working order and on7"1/2 it sounds absolutely superb but is a little bit warbly on3.75 probably because the pinch wheel has microscopic cracks due to starting to perish. As a Newby on these, is it an expensive specialist job to re rubber it or is there an easy solution? I know rubber renovation compound will not work as that will not remove cracks. Has anyone tried adding a thin outer skin to one?
saxmaniac is offline
Old 29th Mar 2015, 1:18 am   #2
Michael Maurice
Michael Maurice's Avatar
Default Re: Ferrograph pinch wheel
I dont know how to re-rubber pinch rollers, but it involves grinding the rubber so that it is perfectly concentric.
If I were you, I'd send the roller to terrys rubber rollers and have it done professionally.
Forum Moderator
Michael Maurice is online now
Old 29th Mar 2015, 2:42 am   #3
TIMTAPE
The Series 5 has a brass pinch roller.
TIMTAPE is online now
Old 29th Mar 2015, 7:55 am   #4
saxmaniac
Tim, sorry, it's a series 2. The rubber is attached to the capstan spindle, the pinch roller is brass. I think in the interests of economy I might try to shave down the rubber in the lathe and try to turn a rubber "bush" to fit. Probably end in tears!
Old 29th Mar 2015, 9:19 am   #5
sp10mk11
sp10mk11's Avatar
Well worth a try though, if I had a lathe I would do allsorts of jobs.
Terry does do an amazing job, he uses very high quality rubber that won't perish in a few years, basically you are getting a brand new part.
There used to be a guy down here who specialised in re-rubbering ferrograph rollers etc but he moved to france some years ago
Good luck
Gary
sp10mk11 is offline
Old 29th Mar 2015, 12:32 pm   #6
Tractorfan
Tractorfan's Avatar
Smile Re: Ferrograph pinch wheel
Of course, the diameter of the capstan is critical to correct tape speed, whereas the pinch roller isn't. So, it'd be an interesting exercise. Luckily, the capstan on my Series Five is still good (so far!)
Cheers, Pete.
Tractorfan is offline
Old 29th Mar 2015, 11:21 pm   #7
saxmaniac
I'm thinking of getting a lump of rubber from a vehicle rubber mount such as a Mini exhaust mounting unless anyone has any bright ideas for a source of rubber.
Old 31st Mar 2015, 6:37 pm   #8
nutteronthebus
nutteronthebus's Avatar
Hi David Durrant remakes pinch rollers for the series 7 try him at Mouse Hall
South Lane
Houghton
BN18 9LN
Any tool can be used as a hammer but a screwdriver makes the best chisel
nutteronthebus is offline
Old 31st Mar 2015, 8:37 pm   #9
dseymo1
A redundant printer will offer a selection of rubber rollers to experiment with.
Keep it in the freezer before trying to machine it.
dseymo1 is offline
Old 1st Apr 2015, 2:36 pm   #10
saxmaniac
Good ideas both. The biggest fun will be boring out the centre I think.
