Old 9th Sep 2017, 5:14 pm   #1
usradcoll1
Default Austin House Step-down Converter.
I picked this item up at a charity shop.
It doesn't seem to be anything special, 100 watt rating. Three core flex, fitted with a BS1363 plug, which still has the 13 amp fuse. It's a auto-transformer design, made in China.
The data sticker states: 220/240 50HZ in, 110/120 60HZ out.
It amazes me, what the Chinese can make a transformer that can reduce the voltage and increase the frequency as well, just joking of course!
It only contains a transformer, a NEMA 5-15r receptacle and an output fuse.
usradcoll1 is offline
Old 9th Sep 2017, 6:17 pm   #2
hannahs radios
Default Re: Austin House Step-down Converter.
If there's no electronics in it I doubt it can produce 60c/s unless the Chinese have found someway to fiendishly clever to do it. The voltage is believable of course any one can do that with a tranny.
hannahs radios is offline
Old 9th Sep 2017, 7:43 pm   #3
G6Tanuki
G6Tanuki's Avatar
Cheap but functional: ideal for running US import equipment in the UK,
Provided the 3-core flex is able to handle 13A in overload [in other words it's 0.75mm or greater] a 13A fuse is OK. Remember that the fuse is there to protect the flex **not the thing the flex connects to**.
G6Tanuki is offline
Old 10th Sep 2017, 1:42 pm   #4
turretslug
turretslug's Avatar
A curious thing to have found in the US- the other way around would make more sense! Yes, the frequency discrepancy is odd, but I suspect that it smacks of a non-technical person being involved in the description on the basis of what probably appears on many appliances of both 110/120V and 220/240V rating without appreciating the ramifications of "Hz", it would have been better if someone informed had been across the labelling process.
turretslug is offline
Old 10th Sep 2017, 2:55 pm   #5
mark_in_manc
Originally Posted by turretslug View Post
...without appreciating the ramifications of "Hz"...
Tangent:
When working in an acoustics lab, we were once baffled for a while when a customer rang (on receiving his report) wanting to know 'what this H2 thing is all about'...
mark_in_manc is offline
Old 10th Sep 2017, 5:18 pm   #6
usradcoll1
The best part about it, was the unit was never used!
The flex was never unwrapped, still had the original twist tie. It seems it's built rather well.
I thought the 60 Hz on the label was a typo.
Old 11th Sep 2017, 3:45 pm   #7
Oldcodger
usradcoil- DIL is from LA, and all her stuff is 110-120. I always thought that over the pond 110-120 AC was standard.
Oldcodger is offline
Old 11th Sep 2017, 5:56 pm   #8
usradcoll1
In the US, all domestic plug-in equipment and appliances are designed for 120VAC.
The wiring installations in residential and small commercial have been 120/240 volts, using two 120 volt legs and a earthed neutral. The 120 volt legs are 180 degrees apart and used together produces 240 volts for large loads. This practice has been in use for at least 80 years.
The only reason I bought the transformer is because it was cheap and it's a interesting conversation piece.
