Old 15th Aug 2017, 5:18 pm   #1
Vakito227
Vakito227's Avatar
Default Drive Belt Sizes
Hi all, I've been servicing my Volvo TD-603 stereo after the cassette deck stopped turning the cassette and was stuck in an infinite loop of auto-reverse. Luckily it turned out to just be a snapped drive belt which measures around 200mm when folded flat x 1mm cross section.
I have looked on ebay and there are plenty of belts with a 1mm cross section although the 'fold length' only goes up to 135mm and this seems constant across all the listings I have seen.
Either I'm measuring my belt wrong or I'll have to look elsewhere for one in the size I need. Could anyone point me in the right direction?
I'll include some pictures soon
Thanks
Vakito227 is offline
Old 15th Aug 2017, 5:37 pm   #2
Station X
Station X's Avatar
Default Re: Drive Belt Sizes
I've several bags of Chinese mixed belts that I can check.
Can you confirm though that you're looking for a belt with a circumference of 400mm, as I'm not too sure what folded length means.
It's normal to specify belts as having a circumference of about 10% less that that of a length of cord wound round the pulleys.
Graham. Forum Moderator
Station X is online now
Old 15th Aug 2017, 7:29 pm   #3
Vakito227
Vakito227's Avatar
Here's some images of how I measured it, the circumference is roughly 125mm ± 5mm.
ID:	147966   Click image for larger version
Old 15th Aug 2017, 7:33 pm   #4
TonyDuell
Do you mean the DIAMETER is roughly 125mm?
TonyDuell is offline
Old 15th Aug 2017, 7:43 pm   #5
Vakito227
Vakito227's Avatar
That is what I meant, my mistake
Pretty embarrassing really considering I measure for a living!
The circumference is 405mm
Old 15th Aug 2017, 10:29 pm   #6
Station X
Station X's Avatar
Sorry, But I don't have any belts that long. 1mm square cross section seems rather small for a belt of that length.
This company has belts which may fit, but none of them matches your exact specification:-
http://www.gbaudio.co.uk/data/belts2.htm#Square
Other suppliers are available.
Old 16th Aug 2017, 11:43 am   #7
Grubhead
I would just go for a 125mm Diameter belt to the nearest thickness. It will either move the parts, or get stuck or slip if it's wrong.
Grubhead is offline
Old 19th Aug 2017, 8:07 pm   #8
Vakito227
Vakito227's Avatar
All working now thanks
