Old 14th Aug 2017, 5:09 pm   #1
acorn
Default Trio 1830 oscilliscope
Good day all
I have a problem with trio 1830 scope not showing a display, if I switch it off and on quick I can see a blured image but not a permanant display are there any known stock faults with this scope or could it be the tube showing its age, but even if that is the case I should see some kind of display.
Acorn
acorn is offline
Old 14th Aug 2017, 6:37 pm   #2
Restoration73
Restoration73's Avatar
Default Re: Trio 1830 oscilliscope
You need to pull out the trigger knob to get a trace in the absence of input signal.
Restoration73 is offline
