Old 30th Apr 2017, 7:34 pm   #61
Skywave
Arrow Re: Racal RA17C tips
Several RA-17s have passed through my hands in which I replaced the BFO assembly with a product detector. The improvement was worth the effort.
Al.
Skywave is offline
Old 30th Apr 2017, 7:40 pm   #62
dtvmcdonald
Default Re: Racal RA17C tips
Exactly what was the improvement? I've tried a product detector on
a couple of receivers and noticed no significant improvement. These all
had, however, plenty of BFO injection, and I never ever tried them
with really high S/N ratio SSB signals, best S/N was probably 30 dB at best.
dtvmcdonald is offline
Old 2nd May 2017, 4:00 pm   #63
Keith
Keith's Avatar
I regularly use an RA17C-12 and find it's SSB performance to be perfectly adequate without any modification.
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is offline
Old 3rd May 2017, 12:14 am   #64
Skywave
Improved resolution of strong SSB signals. The need to reduce the IF gain and increase the AF gain is much less required, if at all. However, there a several suggested ccts. around for a PD for a RA-17: not all will show much of an improvement. Moreover, please note that I am talking about the RA-17 and the RA-17L. I have no experience of the RA17C-12.
Al.
Skywave is offline
Old 3rd May 2017, 6:17 am   #65
Radio Wrangler
Radio Wrangler's Avatar
The RA117 may be worth looking at. It has as standard an S meter reading the AGC line which manages to work normally on CW and SSB, so the AGC is definitely active. The 3-way knob switch for the meter is the obvious difference on the front panel in place of the RA17's toggle switch. You also get a full Watt of audio.
In the early 1980s I bought an RA117 from John's Radio in Birkenshaw (Nr Bradford) The receiver was NOS, taken right out of long-term packaging and put into a slim metal cabinet from a batch which John had had made locally. Inside, the castings gleamed! I used it on aM CW and SSB without an SSB adaptor. I wondered about one, but never happened to find one.
Radio Wrangler is offline
Old 3rd May 2017, 9:43 am   #66
Keith
Keith's Avatar
The RA17C-12 seems to many many similarities with the RA117 - it too has the 3 position meter switch which includes an S-meter position. Possibly it has the same AGC arrangements. I've certainly never had to reduce the RF gain to resolve SSB signals.
Keith Yates - G3XGW
Keith is offline
Old 3rd May 2017, 11:36 am   #67
Radio Wrangler
Ah, that may explain things. Thanks, Keith
