Old 18th Oct 2017, 10:20 am   #21
ms660
ms660's Avatar
Default Re: Push fit connectors for EHT/ RF, high current?
There's a calculator here for what it's worth:
http://chemandy.com/calculators/roun...calculator.htm
Lawrence.
ms660 is offline
Old 18th Oct 2017, 10:30 am   #22
russell_w_b
russell_w_b's Avatar
Originally Posted by astral highway View Post
Thanks Russell, it's helpful to see that effect quantified exactly for the design f.
You're welcome. There's a good section about skin effect losses in Terman and the equation for single round-section copper wire is on page 32. I believe Terman (Radio Engineers' Handbook) is available as a free download, if you haven't a copy. But it appears in the downloadable New England wire catalogue (Litz and winding Wire section) amongst other places.
https://www.newenglandwire.com/newt-catalog.pdf
More importantly, I guess you have to use what you've got, and that's that!
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 18th Oct 2017, 5:42 pm   #23
Al (astral highway)
Al (astral highway)'s Avatar
Yes, it does come down to that. Otherwise it's overspend time - another £45 or so for some thicker stuff.
I have 2mm enamelled copper here, and as I'll hardly ever be operating in CW mode, except for bursts of a few seconds, I think it will be fine. Duty cycle will be between 10 and 25%, and it's already only in class C.
Also, if I'm going to be pulling loops out for tuning, 2mm is about the limit of workable, especially if twisted to 4mm!
Al
Old 19th Oct 2017, 9:34 am   #24
Argus25
No Longer a Member
Astral highway, I would avoid twisting this 2mm wire. Bring a straight length out bent perpendicular to the former surface, make the loop and a straight section back in with another sharp bend to get the wire back into the correct position to keep winding. Have the straight sections leading to the loop touching each other and if you wanted you could solder them together on the straight section too (if the enamel was removed there) to stop the loop pulling apart as you continue to wind the coil.
Argus25 is offline
Old 19th Oct 2017, 12:01 pm   #25
Al (astral highway)
Originally Posted by Argus25 View Post
Astral highway, I would avoid twisting this 2mm wire...
Hey Argus25, I saw this just in time - I'm starting on the winding!
Thanks for your recommendation I will try that technique. The soldering idea is a good one, too, as I'm taking out individual turns and even a half turn, for fine tuning, towards the end of the winding.
Al
Old 19th Oct 2017, 1:32 pm   #26
A rather neat "turns selector" I saw years ago was two bits of copperclad PCB about an inch wide made into a clip. The insulation stopped shorting to adjacent turns and the width allowed high currents without overheating.
Old 21st Oct 2017, 12:13 am   #27
Al (astral highway)
Neat suggestion, MM. I like it; I might try that one, thank you
Al
