28th Aug 2017, 5:50 pm | #1 |
Panasonic NV 7200 not rewinding /forwarding
Hi guys, I have a Panasonic NV 7200 and changed all the belts. Originally, nothing worked at all. The issue is with the idler. When I moved it to the left, the tape played and was able to rewind but didn't forward at all. When I moved the idler to right, play and rewind didn't work but the forward did.
Is it the tyre or the whole idler that's messed up? Where do I get the parts from? There's also a noise coming from the head but the picture is clear. |
29th Aug 2017, 4:55 pm | #2 |
Re: Panasonic NV 7200 not rewinding /forwarding
If you can get the whole idler assembly that should cure it, but it will be the tyre that is the problem. Donberg Electronics seem to have a lot of the spares.
donberg panasonic video recorder spares/ |
2nd Sep 2017, 7:07 am | #3 |
Thank you Grubhead. How do I change the tyre?
3rd Sep 2017, 1:53 am | #4 |
The entire assembly should come out. You then remove the tyre and fit a new one. But it's simpler to fit a new assembly if you can get one.
5th Sep 2017, 10:04 pm | #5 | |
http://www.donberg.ie/descript/1/14157-g.htm |
5th Sep 2017, 10:11 pm | #6 |
The noise from the video head may just mean the discharge spring that bears on the top spindle is in need of a tiny spot of grease.
Andy G1HBE. |
9th Sep 2017, 9:31 pm | #7 |
Thanks guys. I tried to buy from Donbergs but I have to spend at least £20 for them to send the item. Don't know what to buy because I've changed all the belts
