Old 19th Jun 2016, 8:46 am   #21
Jac
Jac's Avatar
Default Re: Aurora problem
Thanks for posting your photos John.
My D16T (and B16T for that) have exactly the same sync "problem".
The black blocks on the beginning of the lines (not visible in the photos because the 16T receivers still have the 5:4 aspect ratio, and the output of the Aurora is 4:3) seem to influence the sync timing.
Jac
Name:	2016-06-08 D16T 161 beeld TCC.jpg
Jac is online now
Old 19th Jun 2016, 9:29 am   #22
Boater Sam
Off the cuff, you have all looked at hum on the power supplies, but TVs being as they are with half wave supplies etc. it may be worth looking at what is on the neutral mains feed.
Boater Sam is offline
Old 19th Jun 2016, 10:00 am   #23
Jac
Jac's Avatar
A lot of the old TV-sets have double sided rectification, like in the annex for the Pye 16T receivers.
Jac
Name:	double sided rectifier.JPG
Jac is online now
Old 19th Jun 2016, 11:41 am   #24
D Cassidy
D Cassidy's Avatar
Good Morning.
Jac I've been re-kindling my interest in TV over the last few weeks and have obtained some books and have been reading up.
I wonder if the issue you have is due to video content not being properly clipped out by the Synchronising separator? From what I have read this gives exactly the same effect as you have got.
This could be due to a leaky coupling capacitor or incorrect biassing of the valve allowing it to not be properly cut off allowing video content through, the black and white blocks could then spuriously trigger the line oscillator stage.
I think though this problem is different to the wavy issue mentioned earlier in the thread. On that note my friend had fed his set from a pure DC source and the effect completely disappears, which discounts any thoughts that the converter is the culprit.
D Cassidy is offline
Old 19th Jun 2016, 1:09 pm   #25
Jac
Jac's Avatar
Hello D Cassidy,
Thank you for your comments.
Yes, that could very well be the cause.
It is not due to any faulty capacitor or incorrect biasing though.
All 16T receivers seem to have this.
Although it might be interesting to see it the design could be improved in this respect.
A nice future project.
Jac
Jac is online now
Old 19th Jun 2016, 6:13 pm   #26
Sideband
Sideband's Avatar
I've been following this with interest. My Ferguson '45' portable suffers from a similar problem. I've literally replaced everything in the flywheel sync circuit but still not cured it (although improved from original}. Problem doesn't really notice on a picture but a testcard shows it.
Something I intend to investigate in more detail at some point.
Sideband is offline
Old 19th Jun 2016, 6:23 pm   #27
Jac
Jac's Avatar
Sideband,
Could you post a picture of how it looks on the left side of the screen?
Is the effect dependent on the screen brightness (in other words: is it the same if the picture is turned a lot darker)?
Jac
Jac is online now
Old 19th Jun 2016, 8:09 pm   #28
Sideband
Sideband's Avatar
Here's a picture during the earlier stages of restoration. I'm not sure about brightness effect. I think it's the same but I'll try and check later and get a better picture.
Sideband is offline
Old 19th Jun 2016, 8:36 pm   #29
peter_scott
peter_scott's Avatar
I think the brightness effect is just due to using a shutter speed faster than a 25th of a second.
Peter
peter_scott is offline
Old 19th Jun 2016, 11:31 pm   #30
Sideband
Sideband's Avatar
Peter. I'm not referring to the bright area across the screen, I'm referring to the post above mine where Jac was asking if the pulling is affected by the brightness setting
Sideband is offline
Old 20th Jun 2016, 8:54 pm   #31
line sync
Today I tried 2 different mains chokes because we thought the one I`d fitted was not up to the job but both of them failed to cure the problem.
I don't know what else we can try.
Robin
line sync is offline
Old 21st Jun 2016, 7:21 am   #32
Jac
Jac's Avatar
Is there perhaps a screened lead between video en sync separator?
I once had a set in which such a screened wire had a screen that was not properly grounded anymore (wire broken).
The cause certainly is not easy to find in your set!
Jac
Jac is online now
Old 21st Jun 2016, 12:56 pm   #33
pichacker
Were there ever any 405 line sets with flywheel sync? I know some DS had it, but did it work on 405?
Only asking as this would give a clue as to whether it is really a sync issue or possibly an image displacement in the line period.
However, are we being too fussy, how often did the average 405 line viewer sit there staring at a stationary test card? (Yes I know the music used to be entertaining).
6.3v on my heaters is no longer enough to get me going in the morning!!
pichacker is offline
Old 21st Jun 2016, 1:30 pm   #34
Sideband
Sideband's Avatar
Yes...lots of them. The first set I ever repaired (Ecko T283 from 1956) had flywheel sync. Used an EB91 as the flywheel diodes.
Sideband is offline
Old 21st Jun 2016, 2:00 pm   #35
evingar
evingar's Avatar
That question did float through my mind as well. In service the viewer would never have noticed this - probably just grateful for a piccy they could see without all light excluded from the room and locked in both the H and V.
Does no harm though to analysis the sets to this level - all part of the rich tapestry of the hobby.
Chris
evingar is offline
Old 22nd Jun 2016, 8:55 am   #36
pichacker
I never realised that flywheel sync had hit 405 so question is, do any of the sets displaying the picture displacement have flywheel sync?
