29th Mar 2017, 11:28 am | #1 |
No head/drum spin after cold storage...JVC VCR HR-S7600EK
I have a JVC VCR HR-S7600EK that has been stored for a few weeks in a cold garage. It was all working before storing but now the video head/drum does not spin up. The tape loads and ejects but goes into standby/shutdown when asked to play etc.. Does anyone have any experience with these before I plunge in? Many thanks
symptoms here: https://www.dropbox.com/sh/xjilg1zpa...BhmO83fda?dl=0 |
29th Mar 2017, 12:06 pm | #2 |
Re: no head/drum spin after cold storage...JVC VCR HR-S7600EK
Have you given it time to warm up to room temperature and dry out? The condensation sensor may be tripping.
29th Mar 2017, 12:18 pm | #3 |
That is the model with dynamic drum isn't it? The gear inside the head that drives it cracks and the machine shuts down as improper operation is noted. Note, no spares are available now, you will likely need to replace the head with a non-dynamic equivalent from a similar model.
29th Mar 2017, 3:45 pm | #4 |
Re: No head/drum spin after cold storage...JVC VCR HR-S7600EK
If you have given the machine a few hours to warm up and dry out as suggested then you could try shorting out the dew sensor in case it's duff. Failing that then as Ian says it's needing a new head.
29th Mar 2017, 6:22 pm | #5 | |
Hello and many thanks for your replies.
Whereabouts is the condensation sensor and what does it look like? Is it a circuit protector? It has been suggested i should suspect these - black in colour and about 3-4mm in length and usually designated ICP301, ICP401 or similar on the circuit board but I'm having trouble confidently identifying them - is 'CP' an abbreviated 'ICP' or something different? Do these have a mode switch -I cannot locate it? I'm afraid your dealing with the electronically illiterate here. My experience extends to replacing the odd bulgey capacitor. I have a multimeter but am not confident how exactly to test whether the drum is receiving power... I've managed to find a service manual online. The machine apparently has an 'emergency display function' for diagnostics, but i have not managed to find th 'N' button on the remote to enter ED mode (see earlier Dropbox link). My apologies for so many questions - I would like to save the VCR if I can - it's a favourite for capturing VHS/VHSC to digital (TBC etc). |
29th Mar 2017, 6:26 pm | #6 | |
29th Mar 2017, 8:01 pm | #7 |
When powered up out of standby, there should be 12v DC present on pin 5 of that drum motor's flat ribbon connector. That's a good place to start! You can easily measure it with a multimeter (negative probe on chassis ground, and positive probe to pin 5).
Just be very careful not to short out any of the pins with the multimeter probe!
Regards, John |
29th Mar 2017, 8:08 pm | #8 |
If it's had 12 hours at room temperature then it won't be a condensation issue.
29th Mar 2017, 8:45 pm | #9 |
It's not a machine I've ever encountered but I'm not aware of any JVC domestic machines ever been fitted with dew sensors other then camcorders.
With no tape inserted does the head spin freely if rotated by hand? John. |
29th Mar 2017, 9:23 pm | #10 | |
29th Mar 2017, 9:24 pm | #11 |
29th Mar 2017, 9:29 pm | #12 | |
On standby pin furthest from centre of drum has 2.02V. When a tape is loaded or ejected this changes to 1.97V and reverts to 2.02V when the machine puts itself back into standby. At no time does it show 12V. I repeated this test in low light, holding a book over the transport area in case of sensor issues, with the same result. |
30th Mar 2017, 12:17 am | #13 |
Can you hear the dynamic drum motor trying to work?
30th Mar 2017, 2:16 am | #14 | |
There might be a little marking on the PCB to tell you which is pin 1, so easy enough to figure out.
Regards, John |
30th Mar 2017, 10:54 am | #15 |
30th Mar 2017, 11:17 am | #16 | |
standby tape in PIN 1 2.02V 1.97V 2 288mv 288mv 3 139mv 4V 4 -3.7mv -26mv 5 0 5mv How do you guys tackle this kind of thing? Is there a way of tracing the fault back from the motor to at least to know which board is culprit? I am aware of the forum rules, so have attached only the Service Man table of contents as a starting point... |
30th Mar 2017, 11:38 am | #17 | |
30th Mar 2017, 12:51 pm | #18 |
ah ...having trouble retaining my formatting
PIN1 standby 2.02V, tape in 1.97V PIN2 standby 288mv, tape in 288mv PIN3 standby 139mv, tape in 4V PIN4 standby -3.7mv, tape in -26mv PIN5 standby 0.00V, tape in 5mv |
30th Mar 2017, 6:39 pm | #19 |
...on further investigation, it looks like PIN5 at the drum motor ribbon connector arrives at PIN1 of CN3001 on the big board.
This agrees with voltage chart info for CN3001: 11.5V at PIN1. I am not picking up this 11.5V at either end of the cable...where to look next? |
30th Mar 2017, 6:50 pm | #20 |
I think Pin 3 is the 'motor start' (control) voltage, so the drum is being told to start-up, but as the 12 volt supply is missing (Pin 5), it's going into shutdown.
Try unplugging the entire flat ribbon cable and check you have your 12 volts on the opposing connector on the main PCB. If you find it there, then the flat ribbon cable is faulty (try reseating), or there is a dry joint on the connector. Failing that, the problem is going to be on the main PCB. The 12 volt rail will have to be traced back, and that's a little more involving. Could be an open-circuit resistor or IC protector..or another pesky dry joint (if you're lucky!) *EDIT* Just saw your latest post, so ignore my middle paragraph. You might also want to check the health of the power supply to make sure a rail isn't missing. If you have the service data anyway, it will tell you what voltages to look for.
Regards, John Last edited by John123; 30th Mar 2017 at 7:04 pm. |
