19th Jun 2017, 1:28 pm | #41 |
Re: Grease
Similar to "Kilopoise" presumably.
19th Jun 2017, 1:44 pm | #42 |
Re: Grease
Rocol is the manufacturer, '
Kilopoise' is one of their trademarked products. "You What!" is the response to the price of a jar David
19th Jun 2017, 1:55 pm | #43 |
Re: Grease
Ah, that makes sense.
At least some enterprising person's decanted tins into small phials available for a few quid on eBay now. N. |
19th Jun 2017, 4:34 pm | #44 |
Re: Grease
Many years ago I added Molyslip in the differential and steering box of my A35 van to reduce the wear. I have some left wich I have used to stop seizing of things like drill chucks. One drop is used neat, it seems to last forever with no obvious liquid present.
I used to service talking books for the blind which often had worn or seized motor bearings. The lubrication experts at work recommended Chromatap as the best lubricant around but I never found anything which would last long in a poor sintered bearing, the shaft always got worn. |
19th Jun 2017, 4:43 pm | #45 | |
Re: Grease
19th Jun 2017, 8:15 pm | #46 |
Re: Grease
"Copper grease" should be avoided on rotational bearings - it's abrasive.
Are we talking about phosphor-bronze 'Oilite' sintered-type bearings? If so then these are best *oiled* rather than greased. The bearing is porous, a bit like a sponge. If you can push the bronze bush out of its housing, soak it in petrol/acetone/brake-cleaner for a few days to remove the age-congealed lubricant, then blast it dry with compressed air and soak it in *thin* oil [3-in-1 or 'sewing-machine-oil' are good options] for a few days to to relubricate it. |
22nd Jun 2017, 11:40 am | #48 | |
Re: Grease
Mike |
22nd Jun 2017, 11:59 am | #49 | |
Re: Grease
http://www.vintage-radio.net/forum/s...07&postcount=8
