Old 9th Aug 2017, 7:38 am   #1
FIXITNOW
FIXITNOW's Avatar
Default AVO Test Bridge with EBF2 valve
picked this up at Kings Lynn radio rally at the weekend
most of the stuff including the restoration guide on this site and web seems to be for a latter version. Any one got a circuit for this earlier version looks as if its had work before there are 2 metal can wax caps in parallel and another black body one that has come a drift one end
Also the case has a hole in it at top in middle towards the back must be original as the in side has a masked square so I am guess a earth stud ??
any got any info on the stud and a early circuit cheers vince
3rd picture shows cap adrift
ID:	147565   Click image for larger version
ID:	147566   Click image for larger version
ID:	147567   Click image for larger version
ID:	147568   Click image for larger version
FIXITNOW is offline
Old 9th Aug 2017, 7:39 am   #2
FIXITNOW
FIXITNOW's Avatar
Default Re: AVO Test Bridge with EBF2 valve
more internal pictures
second and third picture shows 2 metal cased wax caps in parallel
ID:	147570   Click image for larger version
ID:	147571   Click image for larger version
ID:	147572   Click image for larger version
ID:	147573   Click image for larger version
FIXITNOW is offline
Old 9th Aug 2017, 7:40 am   #3
FIXITNOW
FIXITNOW's Avatar
hole in case top
ID:	147575   Click image for larger version
FIXITNOW is offline
Old 9th Aug 2017, 8:07 am   #4
Andrewausfa
Andrewausfa's Avatar
Hi Vince,
I have one with an EBF2 in as well, good to see mine isn't unique. Does the CT8 valve base and bracket look factory to you? If you search back on Avo Test Bridge CT8 valve you'll find some photos of mine and further discussions.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 9th Aug 2017, 8:25 am   #5
FIXITNOW
FIXITNOW's Avatar
yes all looks original valve wise but I think some off the wax caps have been replaced probably in the 60's
but now need doing again
1 has been replaced by 2 in parallel / 1 is a black hard cased and 3 look original
found your thread nice to see another unit
does yours have the case hole ??
http://www.vintage-radio.net/forum/s...ad.php?t=94971
mine is dated March 1941
FIXITNOW is offline
Old 9th Aug 2017, 10:30 am   #6
ThePillenwerfer
ThePillenwerfer's Avatar
I suppose that due to wartime shortages AVO could have used whatever valves they could get at the time.
Mine has a brass binding post on the top. I've always wondered if it was original or added by a previous owner so you've settled that question for me.
ThePillenwerfer is offline
Old 9th Aug 2017, 10:49 am   #7
FIXITNOW
FIXITNOW's Avatar
Could you do me a picture of the binding post then I can see if I can find something close to fit to mine (better than a empty hole)
cheers Vince
PS I have noticed various AVO meters sometimes had a binding post
FIXITNOW is offline
