2nd Aug 2017, 8:20 pm | #1 |
Sharp GF525 speaker query
Hi all just bought myself a cracking Sharp GF525 with a speaker problem. It needs new ones. I haven't received it yet so was just getting the heads up on what I need to get. Cheers Phil
2nd Aug 2017, 9:35 pm | #2 |
Re: Sharp GF525 speaker query
How do you know that it needs new speakers? They rarely fail.
It is ususally more liable to be an amplifier problem. I think this unit has 2 x 6.5" units each with a co-axial tweeter. They are liable to be Far-Eastern OEM types.
Edward. |
3rd Aug 2017, 6:13 am | #3 | |
Or did the seller advise that it "Needs New Ones" ?
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
4th Aug 2017, 12:52 am | #4 |
Hi the seller told me it needs new speakers. I'll wait til zI receive it through I'll let you know. If it is the amp is it an easy] fix? How can I check, I'm very new to this so I'm a bit of novice. Thanks Phil
6th Aug 2017, 8:59 am | #5 |
I've received the radio. In nice condition powers up OK. Right channel is very faint left is OK. Any ideas? Thanks.
6th Aug 2017, 9:32 am | #6 |
The first thing to do is to swop the speakers over to see if the problem is with the speakers or the radio.
6th Aug 2017, 10:08 am | #7 |
Station X
This is a Boom Box and the unit will have to be opened up to swop the internal speaker wiring. Phil 177 Is the problem the same when it's in both Radio Mode & Cassette playback ?
6th Aug 2017, 10:12 am | #8 |
Phil 177
What's your skill level on servicing & repairing such units ?
6th Aug 2017, 11:03 am | #9 |
Phil 177 - Does the unit have a headphone socket?
If so, then plug a pair of headphones in to see if both stereo outputs work on headphones. If one output is distorted and quiet even on phones, then it isn't a speaker fault. |
6th Aug 2017, 5:30 pm | #10 |
Thanks everyone I do think have any experience repairing these but I'll have a go at troubleshooting it. So let me get this right if headphones work on both sides the amp is ok? Cheers Phil.
6th Aug 2017, 6:25 pm | #11 |
Yes, Phil. If this is the case, the trouble could be in the headphone socket, which incorporates switches to cut out the speakers when a jack plug is inserted, or, less likely in my opinion, it could be a faulty speaker. These are easily checked with a multimeter, set to a low ohms rangepreferably an analogue one, connected across the speaker terminals. A reading of either 4 or 8 ohms (approximately) should be obtained, together with a 'click' in the speaker as the test probes are applied. This must be done withe the unit switched off. On the other hand, if the sound from one channel is weak and/or distorted when headphones are used, the amplifier is faulty.
