Old 23rd Apr 2017, 3:07 pm   #1
PowerMac_G4
Default No playback from my Stellaphone ST451
Hi all,
I recently picked up a lovely 'little' Stellaphone ST451 from 1959, it's neat! However I am having a little problem; every function appears to work flawlessly apart from reading audio off the tape. It feeds and plays fine, but no audio. The valves are all glowing and the speaker hums, but I'm at a dead end. I've fiddled to no avail but this is verging on being outside of my comfort zone. Any help the folks here can provide would be greatly appreciated, as resources online are basically non-existent for this machine.
Thanks in advance,
PowerMac_G4
PowerMac_G4 is offline
Old 23rd Apr 2017, 5:57 pm   #2
TonyDuell
Default Re: No playback from my Stellaphone ST451
There's an entry in the radiomuseum here :
http://www.radiomuseum.org/r/stella_...one_st451.html
which might be a starting point.
TonyDuell is offline
Old 23rd Apr 2017, 8:09 pm   #3
vidjoman
Probably more info on the Philips version.
vidjoman is offline
Old 24th Apr 2017, 5:54 am   #4
Steve_P
Steve_P's Avatar
This is a Philips EL3527 in disguise....
http://www.radiomuseum.org/r/philips_el3527_00.html
Note that payback occurs with the green light (DM70) off. If it has those black waxy capacitors on the circuit board then change the lot. No messing....
Check the head connections and the rotary switch. This can be a root of many evils.
Cheers,
Steve P.
Steve_P is offline
Old 24th Apr 2017, 9:21 am   #5
Station X
Station X's Avatar
Service information can be downloaded here:-
http://www.service-data.com/product....70/6070/a14770
Graham. Forum Moderator
Station X is online now
