Old 30th Mar 2017, 8:42 am   #1
soundfactory
Default Revox B77 capstan trimpot
Good morning, whilst doing a recap on my Revox B77 the R14 trim pot on the capstan board has parted company with its wiper (as they do
I've identified it as being a 10k ohms linear, but I'm unsure about the wattage.
The two trim pots I have here are 0.2 and 0.5 watts, I'm guessing these will be too small, does anybody have an idea what wattage I would need?
Thanks in advance
soundfactory is offline
Old 30th Mar 2017, 2:03 pm   #2
MikeCross
Default Re: Revox B77 capston trimpot
Hi This is quite common - from memory they are the same wattage as those used on the input/oscillator cards. I would be happy to fit either of the two you have.
MikeCross is offline
Old 30th Mar 2017, 2:21 pm   #3
soundfactory
Really?! This is great news.
Just wanted to double check as they seemed smaller than I expected when they came in the mail.
Thanks very much for your reply
Old 30th Mar 2017, 6:09 pm   #4
Michael Maurice
Michael Maurice's Avatar
You need to obtain the 15mm types, they are not very common
Forum Moderator
Michael Maurice is offline
Old 4th Apr 2017, 10:25 pm   #5
soundfactory
Just a quick update to close this thread, The trimpot was indeed ok, had to snip the legs from the original and solder to those but it worked out fine once i got it running and adjusted back it to the exact original pitch.
Very surprised to hear the difference in sound after replacing all the Frako's, really worth doing....
