Old 11th Jun 2017, 11:59 am   #121
DonaldStott
DonaldStott's Avatar
Default Re: Bush AC91 - back on track
Bump...!
105 Views and 0 Replies?
Surely someone...
BVWS Member
DonaldStott is offline
Old 11th Jun 2017, 12:14 pm   #122
Nuvistor
Nuvistor's Avatar
The Bush service manual states its the Wave Band indicator, presume it lines up with the dial at the right hand side. Full instructions and a diagram on how it is fitted in the manual page 7.
Frank
Nuvistor is offline
Old 11th Jun 2017, 12:15 pm   #123
ms660
ms660's Avatar
Unless I've got it wrong the component in the picture is the wave change indicator, the black tape shows through the three clear rectangles on the right hand side of the tuning scale glass.
EDIT:....Post crossed....!
Lawrence.
ms660 is offline
Old 11th Jun 2017, 1:09 pm   #124
DonaldStott
Default Re: Bush A.C.91
Thanks Frank and Lawrence - that makes sense now!
Hopefully I can get this component properly refitted - I have the Service Manual.
Anyone got a picture of what a pristine Wave Change/Band Indicator looks like?
BVWS Member
Old 11th Jun 2017, 2:50 pm   #125
Nuvistor
Nuvistor's Avatar
I have never seen one but looking at the manual and photos of restored ones you just need to mark out where the white and black markers should go to line up as Lawrence states in post 123.
I would use black and white paint for the marks, the tape will fall off in time.
Frank
Nuvistor is offline
Old 12th Jun 2017, 8:43 pm   #126
DonaldStott
Oh dear - I'm normally such a careful person but this time it seems that I didn't take enough pictures from the correct angle or make any notes that detail the way in which the Wave Band indicator is attached to the set - aargh!
I have two bolts with largish heads which I assume allows them to be finger tightened and each bolt has a steel washer, a spring washer and a brass nut.
Can anyone with an AC91 advise on which order these are assembled - I know that the top bolt pushes through from the back and seems to lock to the Wave Changer while the bottom bolt pushes through from the front and seems to lock to the set while allowing the Wave Changer to slide up and down.
Any advice or guidance whatsoever would be helpful.
BVWS Member
Old 13th Jun 2017, 8:26 am   #127
tim.norris
Alistair ,best i can do without removing the chassis, hope this is of some use, regards, Tim.
tim.norris is offline
Old 13th Jun 2017, 1:29 pm   #128
DonaldStott
Thanks Tim - that helps a bit as I can see that the bottom bolt doesn't have the spring washer on this side below the brass nut.
Just need the running order on the opposite side for: -
1. spring washer
2. wave band indicator
3. steel washer??
I suppose I could just try all possible variations.
The Wave Band indicator mechanism is working very well after lubricating the spring with some light penetrating oil.
BVWS Member
Old 13th Jun 2017, 6:52 pm   #129
tim.norris
Alistair , can you make out the assembly order if you blow up picture 3 in my post on page one ?
regards, Tim
Old 13th Jun 2017, 9:29 pm   #130
DonaldStott
Thanks again Tim - your picture 3 clearly shows the assembly order for the top bolt so that is now sorted.
The bottom bolt needs to attach firmly yet still allow the wave band indicator to freely slide up and down.
Don't worry, I'll work it out unless someone has a chassis out the case??
BVWS Member
Old 14th Jun 2017, 7:18 pm   #131
DonaldStott
Wave Band indicator now fully reinstated and operational - thanks to all who helped.
Approaching final assembly - maybe power up this weekend??
BVWS Member
Old 19th Jun 2017, 10:51 am   #132
DonaldStott
Final assembly of the Bush AC91 chassis now complete!
Looking forward to a trial power up this week - maybe?
BVWS Member
Old 19th Jun 2017, 11:18 am   #133
Boater Sam
Impressive. Where do you find EF39s with all their coating on? Rare!
Boater Sam is offline
Old 19th Jun 2017, 11:49 am   #134
Radio Tech
Radio Tech's Avatar
I sent Alistair some Sam, I am glad you got it sorted Alistair, time now for your next project, well done.
Ken
Radio Tech is offline
Old 19th Jun 2017, 1:00 pm   #135
DonaldStott
I promise to do a full Roll of Honour when this is completed as it has been a collective effort both in terms of advice/guidance and replacement parts.
BVWS Member
Old 19th Jun 2017, 2:36 pm   #136
Andrewausfa
Andrewausfa's Avatar
Who is Alistair?
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 19th Jun 2017, 9:08 pm   #137
tim.norris
Looking good , let us know when its up and running , Alistair is Donald !
regards, Tim.
Old 19th Jun 2017, 10:10 pm   #138
DonaldStott
Oh dear - unsuccessful power up, with lamp limiter of course.
No sound whatsoever, only a very faint mains hum!
Bulb in set glowing very dimly, orange in fact, while bulb in lamp limiter was very bright!!
Switched wavebands and turned tuning knob, but nothing.
I could see that the two non-metallised valves were glowing dimly - all valves were checked for heater continuity.
Takes deep breath ...
BVWS Member
Old 19th Jun 2017, 10:45 pm   #139
Station X
Station X's Avatar
This set uses an auto-transformer. Check the total DC resistance of the windings. It should be around 210 ohms.
Does the lamp in the lamp limiter still glow brightly if you remove a valve?
Graham. Forum Moderator
Station X is online now
Old 19th Jun 2017, 10:50 pm   #140
Hunts smoothing bomb
Hunts smoothing bomb's Avatar
What wattage lamp are you using?
Lee
Hunts smoothing bomb is offline
