Old 21st Apr 2017, 12:11 pm   #1
pudwink
Default Sony SL-C6UB playing fast
Hi all
trying to get this old betamax running when I play a tape It plays very fast with a black and white picture fast voices like you are pressing fast forward if I press fast forward the picture goes to colour.
any ideas would be very welcome.
pudwink is offline
Old 21st Apr 2017, 4:21 pm   #2
Nicklyons2
Nicklyons2's Avatar
Default Re: Sony SL-C6UB playing fast
Just make sure the capstan pinch roller is engaging properly and that the take-up spool isn't 'towing' the tape through. However the servo panel on these contains many small electrolytic capacitors (sub 10uF). These caps become hideously out of spec with age. Chances are these are the main culprit; if you have a manual you could try and set up the servo panel without changing them but it will drift off spec again after a few days. I replace the lot with modern non-polarised capacitors, a bit bigger but more stable and it saves more grief long-term.
Nicklyons2 is offline
Old 22nd Apr 2017, 6:03 am   #3
Mikey66
Mikey66's Avatar
There were a couple of 0.22uf caps on the bottom (servo) board that used to cause this problem.
Take a look here http://www.palsite.com/slc6tech.html
Regards
Mike C
Mikey66 is offline
