Old 15th Apr 2017, 12:06 pm   #1
GeoffK
Default D.C. Volt Meter
Forgot I made this quite a while ago from a Radio Constructor project (March 1972), powered it up with two PP3's and it still works and is accurate enough to test circuits. It uses the LM709 Op Amp and has a 10x gain with 100K Ohms input impedance. I only fitted resistors for ranges from 100mV to 10Volts as I couldn't afford the larger value resistors at the time for the 30, 50, and 100Volt ranges. I laid it out differently to the original Radio Constructor design with the controls such as Set Zero and meter 'Off protect' switch combined with the on/off switch at the front. The meter only has rough pen markings on but is good enough for home use. The front panel was sprayed with Hammerite and clear varnish that has lasted quite well.
ID:	141009   Click image for larger version
Geoff
GeoffK is offline
Old 15th Apr 2017, 9:09 pm   #2
ionburn
ionburn's Avatar
Default Re: D.C. Volt Meter
Nicely constructed
ionburn is offline
Old 15th Apr 2017, 10:05 pm   #3
ParcGwyn
ParcGwyn's Avatar
Nicely made, I always like to see homemade test equipment.
Dave
GW7ONS
ParcGwyn is offline
Old 15th Apr 2017, 11:38 pm   #4
Peter.N.
Very neat, somewhat above my standard of construction.
Peter
Peter.N. is offline
Old 16th Apr 2017, 10:15 am   #5
GeoffK
Thanks for all your comments, it seemed more fun back then to buy components from places like Home Radio and Henrys without to much regard of it being uneconomic to make. The yellow switch wiring is a bit untidy as I thought I might get round to fitting the remaining resistors.
Geoff
GeoffK is offline
Old 17th Apr 2017, 6:22 pm   #6
MrBungle
MrBungle's Avatar
I like the hammer finish. I come from a family that applied Hammerite to literally everything so I have fond memories
Good point with the economics of building versus buying stuff. I recently built a FET voltmeter myself. Yes you can get a perfectly good DMM for £2.68 on CPC and my "main" Fluke, an 8021B, cost me £21. I must have spent twice that building a technically inferior voltmeter. However, I learned a lot more building something than buying and enjoyed the process immensely and that is priceless.
It's still more fun to build versus buy.
MrBungle is offline
Old 18th Apr 2017, 9:42 am   #7
GeoffK
This is the circuit of the D.C. Voltmeter. I agree about the Hammerite it is a very good paint.
Geoff
GeoffK is offline
