28th Apr 2015, 3:55 pm | #1 |
Bush A1005 Record Player
Alright guys!!
I have just recently bought a Bush A1005 Record Player and it all plays sound sounding good! just one thing there is a slight knocking noise which I think is coming because the bearings look like a little knackered. If I find a replacement bearing do you think its possible to change this myself? I have had a little look and found that a mechanism blocks me from getting to the bearing so I would have to take it off, which I found wasn't that easy. Any help or pointers would be massively appreciated Many thanks, Simon. |
28th Apr 2015, 4:06 pm | #2 |
Re: Bush A1005 Record Player
Have a look at this post, worth reading it all but post 5 and 6 may help.
https://www.vintage-radio.net/forum/...ad.php?t=75401 Edit. Just be careful of any high voltages in the player. |
28th Apr 2015, 4:07 pm | #3 |
I'm not familiar with this deck, but I'm sure someone else will be along shortly.
Is this an idler wheel driven system? It will be a rubber wheel that presses against the motor shaft and drives the rim of the turntable on the inside. Unfortunately with years of storage, if the wheel was left engaged they can develop a small dent which you hear each time it goes round. It may be possible to careful sand or machine a thin layer off the wheel, the size isn't critical for speed, so long as it makes good contact with the deck and the motor shaft. Replacement is easier, if one can be found. |
