Old 9th Oct 2017, 10:09 am   #1
NickG0HIK
NickG0HIK's Avatar
Default Can any one identify this Solid State, valve rectifier replacement?
As per title,
A friend was asking for a solid state rectifier for a valve project some time ago. I knew that I had a couple, but it has taken me ages to come across them (well one of them actually).
Before I give it to him (if he still needs it) I would like to know the specs.
It's an IO base, appears to be marked AEI HTU2-2A, but it's pretty worn lettering, so it could be something else.
Thanks
Nick
NickG0HIK is offline
Old 9th Oct 2017, 10:26 am   #2
ms660
ms660's Avatar
Default Re: Can any one identify this Solid State, valve rectifier replacment
HTJ2-2A..link for ID only (if allowed):
http://www.ebay.co.uk/itm/AEI-HTJ2-2...-/391372037637
Lawrence.
ms660 is offline
Old 9th Oct 2017, 10:28 am   #3
cmjones01
It's a rather lovely thing, that. The glass envelope is so much more satisfying than a couple of 1N4007s wedged into an octal base.
Chris
What's going on in the workshop? http://martin-jones.com/
cmjones01 is offline
Old 9th Oct 2017, 10:57 am   #4
NickG0HIK
NickG0HIK's Avatar
Thanks Chaps,
Got it now, one seller says that it's equivalent of GZ32 etc, I'll pass that on to my mate.
Yes, so much nicer than a couple of diodes wedged in to the holder with matchsticks
Regards
Nick
Old 9th Oct 2017, 11:20 am   #5
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
I doubt if I'd pay £25 for one of those. Rather do as I once did in a Roberts P5A, which was to solder a couple on 1N400x diodes to the valve base, with appropriate series resistor, using, IIRC, unused pins, then leave the faulty rectifier valve plugged in, but disconnected, so that the above-chassis appearance wasn't altered.
'LIVEWIRE?' is offline
Old 9th Oct 2017, 11:51 am   #6
Reelman
Reelman's Avatar
Birkett of Lincoln was selling SS “valve” rectifiers at the Hamfest the other week for 50p, new and boxed. He appeared to have quite a few.
Peter
Reelman is offline
Old 9th Oct 2017, 9:13 pm   #7
NickG0HIK
NickG0HIK's Avatar
50p a bargain, £25 maybe not.
But I have had these knocking around for years so glad that someone in our club can make use of them.
Nick
Old 9th Oct 2017, 10:56 pm   #8
AC/HL
AC/HL's Avatar
I've got a couple somewhere in the junk pile. Not glass though, cylindrical aluminium, from old Pye PMR kit I think.
AC/HL is offline
Old 10th Oct 2017, 8:57 pm   #9
Jon_G4MDC
Jon_G4MDC's Avatar
Oh, now, Hello Bill, AC/HL.
I think I remember something like that in a Pye U450L maybe?
Strange item, never did get to the bottom of it...<digging>
Jon_G4MDC is online now
Old 11th Oct 2017, 6:42 pm   #10
Julesomega
Julesomega's Avatar
Default Re: Can any one identify this Solid State, valve rectifier replacement?
I pulled a couple of plastic-packaged "5R4" devices from some 60s equipment a long time ago: made by STC
Julesomega is offline
Old 11th Oct 2017, 7:15 pm   #11
G6Tanuki
G6Tanuki's Avatar
I remember the aluminium-cased [stuffed full of BY100s] jobs in Pye F27 base-stations.
"International Rectifier" have historically offered a range of these: I've used their "IR14" octal-based offerings in plenty of cases: STC/AEI also did a "CV7137" with similar intent:
http://www.tubecollector.org/cv7137.htm
G6Tanuki is offline
Old 11th Oct 2017, 8:39 pm   #12
TrevorG3VLF
TrevorG3VLF's Avatar
I have somewhere a couple of semiconductor rectifiers on octal bases. The connections were different from the normal 5R4, 5U4 connections, so be warned.
TrevorG3VLF is offline
Old 12th Oct 2017, 5:40 pm   #13
barretter
AEI in Lincoln used to make a solid state bridge rectifier on an octal base, the CV7136. Perhaps Mr Birkett bought up their stock?
ID:	150647   Click image for larger version
ID:	150648   Click image for larger version
barretter is offline
Old 10th Mar 2021, 5:58 pm   #14
paulsherwin
paulsherwin's Avatar
Reopened by request.
paulsherwin is online now
Old 10th Mar 2021, 6:50 pm   #15
Julesomega
Julesomega's Avatar
Came across the STC octal solid state rectifiers again today so I measured it: wondered if there were any power resistors, but the heater pin 8 is absent, and the two diodes just measure as a normal Si diode. It is a replacement for the 5R4, the full type number of the device shown above is AV/5R4, and there are date codes? such as B67 and C67 which seems appropriate for the period when I found them
- Julian
It's good here
