Old 20th Nov 2017, 5:21 pm   #1
backflipper
Default Unknown Vintage Test Equipment
Hey all
I just picked up some old HP logic state analyzers and there was another piece of equipment that I picked up which I have no idea what it is.
It has:
2 inputs (Record +/- and Audio Osc. +/-)
1 Output (Tube Volt meter)
2 multi turn dials.
It's pretty basic inside and only has 2 variable resistors controlled from the dials. The schematic would look like this:
+Record >---+
50 ohm /----> Tube Volt Meter +
-Record >----+
+Audio Osc. >---+
50Kohm /----> Tube Volt Meter -
-Audio Osc. >----+
Can anyone tell me how it may have been used?
[Edit] Added quotes to schematic to keep the formatting correct.
[+Edit] That didn't work!!!
backflipper is offline
Old 20th Nov 2017, 5:30 pm   #2
backflipper
Default Re: Unknown Vintage Test Equipment
Ok I have attached a crude schematic
Name:	Unkown test gear.jpg
Old 20th Nov 2017, 5:47 pm   #3
Station X
Station X's Avatar
Can you post a picture of the actual item?
Graham. Forum Moderator
Station X is offline
Old 20th Nov 2017, 6:01 pm   #4
backflipper
Yes I can.
Attached.
Name:	Unkown test gear photo.jpg
Old 20th Nov 2017, 6:08 pm   #5
Station X
Station X's Avatar
Looks like some kind of comparator/calibrator.
If the two inputs are equal the meter reads zero depending on the settings of the input devices and the pots?
Old 21st Nov 2017, 12:55 am   #6
backflipper
Thanks!
