19th Oct 2017, 10:38 pm | #1 |
Capacitor voltages?
I silly question but some non electrolytic yellow poly capacitors are marked for example 630v and some 630v DC I assume these are both the same so I thought I would ask as its niggling at me!!
Cheers Kev |
19th Oct 2017, 10:45 pm | #2 |
Re: Capacitor voltages?
Hi.
From my understanding the voltage rating of a capacitor is the DC rating unless otherwise marked in which case it will be marked as 400Vac for example to indicate it's AC rating. Regards Symon |
19th Oct 2017, 10:47 pm | #3 |
I think I have answered my own question looking at a thread on X/Y capacitors which the working voltage is AC and all others the working voltages are DC
19th Oct 2017, 11:11 pm | #4 |
Thanks Symon our post crossed! Thank you for confirming that, its much appreciated
Regards Kev |
19th Oct 2017, 11:31 pm | #5 |
Yes, always assume the rating is DC unless it is clearly marked AC. The DC rating will always be higher than the AC rating.
20th Oct 2017, 2:37 am | #6 |
Rule of thumb says: if no AC value is given, assume a factor 3 lower than the DC value (actually 2 times sqrt 2) and no high dV/dt applied unless it's a polypropylene capacitor.
20th Oct 2017, 2:39 pm | #7 |
Thanks Guys much appreciated.
Kev |
