17th Aug 2017, 8:06 am | #1 |
Hitachi KST 3400E - help with wiring
Hello
I have just bought an old radio/cassette player - but the plug has been removed - how do I know which of the 2 wires is live and which is neutral so I can add a new plug (was going to use low 3a fuse)?... both wires look the same and there are no colours! (see pics attached).. I have read previous postings saying to be careful before turning on - but this was sold as working (it has cable ties on the wiring so looks like it has been looked at previously inside maybe) - I think they just removed the plug for safety reasons - but I don't know how you work out how to put a new one on with this cabling - any help would be much appreciated. Thanks for your time any help you can offer. ps I've attached pictures of radio/wiring |
17th Aug 2017, 10:14 am | #2 |
Re: Hitachi KST 3400E - help with wiring
You don't need to identify line and neutral with this sort of equipment, as the mains is fully isolated by a transformer, though it probably wouldn't meet modern safety standards. Just separate the two wires, then connect one to the N pin and the other to the fuseholder (and fit a 3A fuse as you suggest).
It does look as if it may have been got at internally, so be prepared for some interesting times ahead. It may also need new belts for the cassette deck if these haven't been changed recently. |
17th Aug 2017, 10:59 am | #3 |
Thank you so much for your help
Yes, am expecting a few things will need doing - but it is really just for fun - just planning on cleaning it up and hoping it works and then take it from there... Thanks again. |
