2nd Jun 2017, 9:50 am | #1 |
Westminster PWR2 restringing.
Are there any tricks or tips to this? I can see that there are one and a half turns around the large wheel but do I wrap the thread once or twice around the top wheel? I think the tuning cap needs to be fully closed but where should the dial pointer be?
Do I start at the spring? With it attached to the wheel or loose? All help or diagrams gratefully received! P.S. If you look at the wavechange card at the top of the first picture, it's actually a bit of an Ovaltine pack for export only!
Regards, Ken. BVWS member |
2nd Jun 2017, 10:33 am | #2 |
Re: Westminster PWR2 restringing.
As a rule, tuning gang at max capacitance ie fully closed/meshed. Pointer at highest wavelength (metres) that's lowest frequency (khz).
Depends how the pointer is fixed to the cord, but I start in the middle with a length of new cord a good bit longer than the original, work both halves around till you have 2 ends at the spring remembering which way it pulls when the spindle is turned to ensure that it then opens the gang and moves the pointer the right way. You should finish up with one full turn around the gang pulley with the ends in the middle of the turn, never 2 turns. I fit the spring last, taking all slack out first, knotting the 2 ends as far away from the spring anchorage as possible and then hook it on. If its a bit slack, unhook it and twist it round a few times then re-hook it. Do not move the gang pulley on the spindle or you will make it even more difficult. Do you have the service sheet? They usually give you a clue. Masking tape is handy to hold the cord on pulleys whilst you work. Last edited by Boater Sam; 2nd Jun 2017 at 10:36 am. Reason: added |
3rd Jun 2017, 6:53 am | #3 |
Thanks Sam, I'm using masking tape and two pieces of stiff wire formed into hooks/loops as there isn't much room.
I'm halfway through the process but I've had to stop for now as I'm entering my Seville orange marmalade into the local country fair! I'll post again when it's finished and give more details in case there's anyone else wanting to do this radio. P.S. I had to open the tuning cap to get the cord started, it will be closed again when I've got it around the bottom half of the large wheel.
17th Sep 2017, 12:45 pm | #4 |
Westminster PWR2 restringing, still not right!
Three months ago I started to restring this radio (thanks to Boater Sam for the tips), but as you will see from the pictures it's not quite right!
The first picture shows the tuning cap fully open and the dial indicator in the correct position. The second picture shows that the cord on the upper pulley has run out of travel and is preventing the tuning cap from closing. Has anyone else done a restring on this model or can anyone photograph their working Westminster for me? I'm determined to crack this before I progress to recapping!
17th Sep 2017, 1:12 pm | #5 |
You need to wrap the cord round the upper pulley more than once so it doesn't run out of travel.
Generally, with the pointer centralised, then starting from the point where the two "strands" of the cord come through the holes in the pulley you wrap one strand CW and the other ACW. This will enable the pulley to make a complete turn before it jams. You may need two or more turns in each direction, as the pointer has a lot of travel and the pulleys are different sizes
17th Sep 2017, 1:35 pm | #6 |
Thanks Graham, that's exactly what I thought someone would suggest! I'll start again tomorrow.
(My marmalade won second prize!).
7th Oct 2017, 7:40 am | #7 |
Success!
Start from the middle of 30 inches of drive cord, attach it to the clip on the top pulley. (there are 3, at 12, 3, and 6 o'clock, it's the 12 o'clock one). The left-hand side goes anticlockwise one full turn and is held by masking tape. The right-hand side goes clockwise and is taped down. (See pic 1). Take the cord through the brackets. Note that the tuning gang is partly open. This helps to reach the slot (LHS) where the cord is tied to the spring. The attachment point for the spring can be seen on the right. (See pic 2). Now the LHS of the cord goes anticlockwise around the gang pulley and into the slot, the RHS does the opposite, using more tape as you progress. (See pic 3). All that remains is to knot the cord and twist it to tighten, and attach the spring to the clip. Now turn the tuning knob to close the gang. It won't close all the way,but as there is a clutch mechanism, a gentle press on the vanes will close them. The pointer can be put in approximately the right place at the extreme left of the dial,until you're ready to realign the radio. Thanks to Boater Sam (don't give up on us newbies!) and Graham for the great tips. I'll be putting in a request for a legible circuit diagram as mine is a very nicotine brown smudge! P.S. If anyone needs more help I've got more pictures.
7th Oct 2017, 9:12 am | #8 | |
Well done.
If you post a good picture of what you have, you may find that someone, not me, will redraw it for you and post it online.
