Old 26th Jun 2017, 10:54 pm   #1
Nukeybrown
Default Variable resistors
Is there such a thing as 120ohm skeleton variable resistor or similar size?
Nukeybrown is offline
Old 26th Jun 2017, 11:06 pm   #2
Skywave
Arrow Re: Variable resistors
No - least, not that I know of. But is that value critical? Will 100Ω do? Will a 100Ω pre-set + 20Ω fixed in series do the required job? Or 10Ω + 100Ω pre-set + 10Ω ?
Just a few thoughts.
Al.
Skywave is offline
Old 26th Jun 2017, 11:07 pm   #3
Station X
Station X's Avatar
Default Re: Variable resistors
It would help to know the proposed application.
Graham. Forum Moderator
Station X is offline
Old 26th Jun 2017, 11:20 pm   #4
Nukeybrown
Im trying to set a 30mA current on an amp board where the original variables are shot. There 4 variable resistors in total across 4 boards (4 channel amp) , the issue, not necessarily for me but for future is the resistors sit on the boards in opposite to each other eg back to back. The literature that comes with the set says turn all pots to zero before starting but because theyre opposites and are turned from the back side of the circuit board if all are turned anticlockwise your in effect turning 2 of the 4 upto maximum not minimum.
Ive established that the 30ma setting is around 98ohms on a variable pot but could be slighly just over the 100ohm on others . This would give no room for movement should 100+ be needed. As explained above i think a lot of people are going to say closest one would be 220ohm variable , this would cause an issue with the full turn if turned the wrong way as would send the mA current upto 60-90 which i was trying to avoid. If 120ohm existed this would alleviate this issue to some degree leaving max mA full turn down to some 40mA
I hope that makes sense.
Old 26th Jun 2017, 11:22 pm   #5
Nukeybrown
I have read about fixed resistor across lugs of variable but it does funny things to the curve or so i have read. So i guess what i am trying to do is make a 220ohm variable into a 120ohm.
Old 26th Jun 2017, 11:39 pm   #6
Skywave
Question Re: Variable resistors
Originally Posted by Nukeybrown View Post
I'm trying to set a 30mA current on an amp. board where the original variables are shot.
Since 120Ω is not a standard value for a pre-set, what were the values of the original ones which you say are now shot?
Al.
Skywave is offline
Old 26th Jun 2017, 11:47 pm   #7
Nukeybrown
Its hard to tell , if you look at schematics they show as an eye watering 50k which is where the issue started as they had previously been turned up or down, overheating the first channel and burning out components. Theyre shot as when measured they jump from say 200ohm to 35k in a mm turn then all over . With a 50 k pot it would be very hard if near impossible to get 98ohm easily. I cant take a lot of the schematic as true as it says there should be 4 fuses on a board one for each channel but this board doesnt exist in mine. All i know is that with 98ohm i can happily set the 30mA current correctly as per the service data. Even a 220ohm pot is giving too much scope for damage just imagine what 50k would allow.
Old 26th Jun 2017, 11:52 pm   #8
Station X
Station X's Avatar
Skywave's suggestion is a good one.
Old 26th Jun 2017, 11:54 pm   #9
Skywave
Lightbulb Re: Variable resistors
Use a 220Ω or 200Ω pre-set. But before you fit it, first set its wiper so that max. resistance will be presented to the associated cct. when it is fitted. When you come to adjust it (using an appropriate instrument - a milliammeter, say), just adjust the wiper very slowly. Perhaps put a mark using Tippex on the 'high resistance' end of the pre-set so that you can keep track of 'which way is which' when you adjust that pre-set.
Al.
Skywave is offline
Old 27th Jun 2017, 10:34 am   #10
G8HQP Dave
Are they used as pots (3 connections) or variable resistors (2 connections)? If the former then the total resistance probably doesn't matter too much, within reason. If the latter, which you seem to imply, then if you know you need something quite close to 100ohms then use 47ohms variable plus 68ohms (or 82) fixed.
G8HQP Dave is offline
Old 27th Jun 2017, 10:47 am   #11
Silicon
My experience of that type of 'budget' variable resistor shown in the photo is that they can become intermittent/ open circuit.
I would fit a better version if it was possible.
How about a 220R pot with a 220 R resistor in parallel?
Silicon is online now
Old 27th Jun 2017, 11:03 am   #12
Station X
Station X's Avatar
Good point by Dave as too whether of not the pots are wired as potential dividers. I had assumed not, as 98 to 100R appears to be the critical point to get 30mA. However that hardly fits in with the originals being 50k!
We need a circuit.
Old 27th Jun 2017, 11:44 am   #13
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
As I've mentioned before in these forums, I replace skeleton presets of the type shown with enclosed types such as Piher or other similar brands. These are available in both horizontal & vertical mounting types in two different physical sizes which fit the same PCB spacings as the skeleton types, and are made in the usual standard values, but this doesn't include 120 ohm
'LIVEWIRE?' is offline
Old 27th Jun 2017, 2:56 pm   #14
Any possibility of the circuit segment where these are used?
Old 27th Jun 2017, 3:49 pm   #15
G8HQP Dave
I find it hard to believe that a circuit calling for a 50k pot needs it to be adjusted to '100 ohms' to get the correct current. Something is wrong somewhere. Show us the circuit.
Old 27th Jun 2017, 4:44 pm   #16
Nukeybrown
I agree dave but it is. Its a clarion ma4000f amp
Old 27th Jun 2017, 8:48 pm   #17
G8HQP Dave
Circuit? You can show the relevant section without violating copyright.
Old 27th Jun 2017, 9:42 pm   #18
Nukeybrown
I had to pay and download the pdf schematic but here goes if you can read it.
ID:	145251   Click image for larger version
ID:	145252   Click image for larger version
ID:	145253   Click image for larger version
Old 27th Jun 2017, 9:45 pm   #19
Nukeybrown
Where it has ABCD up from the rectifier circuit these should go to 4 x 1.5a fuses then to the amp circuit. These don't exist in this set. Not sure why they're not there as this would protect each amp channel but they're not there or ever have been.
The variable resistors are only using legs 1 & 2.
Old 27th Jun 2017, 10:10 pm   #20
Station X
Station X's Avatar
Which pots is it you want to replace. I can't read the circuit designations of the pots on the diagram and they don't appear to have ohmic values stated. I assume you got the 25k value from the parts list?
Are those Temperature Dependent Resistors wired in parallel with some of the pots?
