7th Jun 2017, 12:55 pm | #1 |
GRUNDIG TK23 -loose motor pulley
As thread title. Was given this ancient beast to look at, chassis as TK14/18/27. Motor turns but pulley is loose on shaft.
I have discovered that the problem was probably initially caused by a distorted/cracked zinc alloy pulley /idler which, as it had expanded, shoved the motor pulley over to one side when attempts were mde to use the m/c. Will post a wanted note in due course. There are no visible allen screws, just a coiled spring around the lower part of the shaft. What am I missing ?! TIA
Regards, Ben. Last edited by ben; 7th Jun 2017 at 1:03 pm. |
7th Jun 2017, 1:20 pm | #2 |
Re: GRUNDIG TK23 -loose motor pulley
One way clutch, spring wraps tight on shaft in one direction only.
7th Jun 2017, 4:05 pm | #3 |
Hi Ben I broke up a TK18 recently and I've got most of the pulleys etc. Anything you need just ask. I've got a complete coupling spring and motor pulley, your spring may have broken in the middle. FOC, just postage. Only possible fly in the ointment may be that yours is a 2 speed TK23, mine was a single speed TK18, the motors may be different.
Peter. http://www.vintage-radio.net/forum/a...1&d=1496847619 http://www.vintage-radio.net/forum/a...1&d=1496847619 |
7th Jun 2017, 10:13 pm | #4 |
Thanks for the responses, and to peter for the kind offer of spares - I will send you a PM as this machine is missing a few bits. The most important item is the damaged idler though.
It is single speed 4 track - I think it the TK27 might have been dual speed. That pulley looks different though, this one has no fan blades. I suppose that to reattach the spring I will have to take the motor out or possibly the supply spool table, as I cannot gain good access to the spring. Will keep fiddling.
Regards, Ben. |
13th Jun 2017, 11:58 am | #5 |
Managed to push the spring up onto the brass pulley using flat bladed screwdriver and pliers, machine on test now. Take up spool table seems to be riding a bit high.
Regards, Ben. |
