Register FAQ Forum Rules Calendar Mark Forums Read
Old 6th May 2012, 1:17 pm   #1
Trebor1220
Default Hameg 203-6 oscilloscope
I have a problem with channel 2, the calibrator 2V p-p on channel 1 is OK, on channel 2 it reads 1.8V p-p. To check the input modules I Swopped CH1 to CH2 and CH2 to CH1. I got the same readings. So conclude the input modules are OK. Checked IC701 with IC702 there are voltage differences. The Y-Gain pot VR702 is turned full on (that is zero ohms reading across it) I have the schematic for the Hameg 203-6, but there no voltages shown on the diagram. I’ve changed some of the small electrolytic caps, the voltages at the P-Test point are OK. Also swapped the IC701 with IC702, but still the same readings. Does anybody have any clues?
Many thanks.
Rob.
Trebor1220 is offline   Reply With Quote
Old 6th May 2012, 1:45 pm   #2
kernowcam
Default Re: Hameg 203-6 oscilloscope
There are quite a few manuals on the net. I seem to remember getting mine from the Hameg site.
kernowcam is offline   Reply With Quote
Old 8th May 2012, 10:40 am   #3
Trebor1220
Yes I got mine from Hameg, had a look at other models they seem to have voltages marked on them but not the 203-6.
Many thanks.
Rob
Old 8th May 2012, 12:47 pm   #4
dave cox
dave cox's Avatar
Is the calibration source accurate ?
You could check independantly with a DC voltage source and a test meter ...
dc
dave cox is offline   Reply With Quote
Old 8th May 2012, 9:30 pm   #5
Trebor1220
H'i (Hi,)
I think I've found the problem, on the Y-Pos II (VR705) pot it read over 700+ ohms and the value on the diagram should be 470 ohms, tested this by adding a 1.2K across VR705 to bring value down. Now it reads 2V pp. So now it's time to order a new 470 ohm pot. Thanks guys for the input.
Many thanks,
Rob
All information and advice on this forum is subject to the WARNING AND DISCLAIMER located at http://www.vintage-radio.net.
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
